Re-tiling Shower Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-29-2012, 11:05 PM   #1
Re-tiling shower wall
I am in the process of re-tiling the walls in a shower. (I am not replacing the tub as it is in good condition) In the demo process I discovered that it looks like behind the tile is green board over dry wall. There does not appear to be any water damage. I am assuming that it is recommended to replace the green board with hardi backer or something similar. I was wondering if I should take it down to the studs or if it would be ok to re-apply the hardi backer over the drywall.
nurseblayne is offline   Reply With Quote
Old 11-29-2012, 11:14 PM   #2
Rewards Points: 13,960
Take it down to the studs, shim out the wall so the tile board will come out just over the lip on the top of the tub.
The tile board should be installed to within 3/8" of the top of the tub.
SusanEB (11-30-2012)
Tiling a shower wall tracysnow Kitchen & Bath Remodeling 0 03-14-2012 05:12 PM
Shower install on outside double wall construction boerssd Plumbing 0 01-16-2012 01:02 PM
how to reduce splash for roman shower (wall vs ceiling shower head) MLMIB Kitchen & Bath Remodeling 2 12-26-2011 02:12 PM
Mating tiled wall to fiberglass shower pan? lizardrider Kitchen & Bath Remodeling 6 05-15-2011 01:21 PM
Wall Tiling... s4alex General DIY Discussions 4 06-02-2009 12:04 PM
