Re-doing A Shower Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 11:11 PM   #1
shower surround
Greetings all:
I am a bit perplexed as to how to properly deal with the edge of this shower. As you can see from the photo (http://www.flickr.com/photos/47944138@N07/4522574676/), the lip along the edge of the surround basically extends as far as the wall does before going horizontal (just above and behind the shower head). The provious owner had simply applied some drywall compound, then taped the corner and painted over that joint. The humidity of the shower makes a mess of it in no time. Does anyone have an idea as to how to appropriately deal with this edge and make it last?
Thanks so much.
belizeanbus
belizeanbus is offline   Reply With Quote
Old 04-16-2010, 08:16 AM   #2
Re-doing a shower surround
2 threads on same issue merged
Moderator
Old 04-16-2010, 11:17 AM   #3
General Contractor
I can't quite understand what you have written in your post, but I think I am looking at a shelf or ledge behind the shower head. If that's the problem, you might want to tile it or replace/cover it with a piece of vinyl board.
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
Old 04-16-2010, 12:38 PM   #4
To clarify, my question is more about how to properly cover the lip or flange that surrounds the shower (for nailing to the studs). Ordinarily, you would have a flat wall there, and simply drywall right over the flange, I would assume. In this case, where the flange ends, an inch or so above the surround, there's a 90 degree angle for that shelf.
Previous owners had simply put drywall tape around that corner and covered it with mud. But that doesn't stand up to the moisture.
I was thinking of cutting a narrow strip of water proof drywall and gluing or nailing it to that flange, then taping the corner where it meets that shelf and finishing it off with mud and then paint. Does this sound right? Is there any other special water proofing material that might be employed here?
Thanks!
Old 04-16-2010, 09:21 PM   #5
DIY staff
Rewards Points: 7,174
The simplest nice looking fix---'cap' the top of the wall with a piece of 1x6 white vinyl exterior trim board.(Azek)
Tuck a bit of trim made of the same material between the top of the surround and the bottom of your new white cap--Caulk(white polyseamseal) Done
---Mike--
Old 04-16-2010, 09:58 PM   #6
Rewards Points: 1,910
Get rid of the edge. Continue the wall up to the ceiling so there's no horizontal corner.
Old 04-17-2010, 01:25 AM   #7
Pro
Nostco's Avatar
Honestly, what you're asking for I cannot in good conscience advise.
The above poster's idea is worthy of a nod, but I know what he's thinking and it's the same thing I'm thinking...you need to redo that shower and do it properly. If you absolutely have to keep the shower as is either go vertical with cement board and tile, or tile at least all the way up to the ceiling ( don't know what the backer is...guessing regular drywall or lathe and plaster?).
Having a sill like that is ok, but involves having proper backer, membrane, maybe even pvc liner, proper slope, tile, etc. to ensure no water penetration/stagnation.
Nostco is offline   Reply With Quote
Old 04-17-2010, 04:28 PM   #8
Registered User
Rewards Points: 526
Is that a T&G wood ceiling above the shower?
Be safe, Gary
Old 04-17-2010, 05:26 PM   #9
If you intend to keep it like it is I'd use cement board & then seal & tile it all, walls included.
Seal - redguard, ditra or ??
For the shelf I'd search for 1 solid piece of material to use
Angled to drain to the front
Also make sure you have a good fan to get rid of the humidity & use it
Problem is if it has been falling apart for any length of time there may be rot & mold etc behind the walls now
Old 04-18-2010, 11:57 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yeah, that's kind of a bogus installation. The opening was closed-in to accommodate the size of the store-bought shower kit.
You should understand there is no such thing as "waterproof drywall".
You may be able to clean up a little then paint those areas with an epoxy paint being sure to caulk the junctures fully.
Mike has a fair idea but I'm thinking that along those lines the use of a piece of aluminum fascia cap/cover would be better. They come prefinished. That with some caulk, would waterproof that area for good. Just be sure the area is totally dry if you cover it with the suggested cap technique.
XXX
Shower Surround & drywall transition mchull Drywall & Plaster 5 08-19-2010 03:31 PM
Tiled Shower Surround Help CluelessNewbie Kitchen & Bath Remodeling 4 02-10-2010 09:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 02:36 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
