Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-05-2012, 03:35 PM   #1
Re-caulking Shower, quick question...
Need to re-caulk top edge of shower/bathtub, but the caulking along the side edges seems fine. Can I just redo the top edge, or do I need to remove and redo all the caulking all the way around, even if it seems fine, and redo everything?
mnhthiessen is offline   Reply With Quote
Old 11-05-2012, 03:54 PM   #2
No reason to redo anything that's not failing or molding up.
Old 11-05-2012, 05:45 PM   #3
sdsester's Avatar
Just make sure you get a tight seal at the corners where old caulking meets new or you could develop problems where they join up.
If this is old silicone caulk you have to carve out remember new silicone will not stick to old.
sdsester is offline   Reply With Quote
Old 11-10-2012, 09:03 PM   #4
I need help , I replaced grout with caulking. I guess I exceeded the 1/4 inch amountCuring limitations as it is not cured after 24 hours. I am wonder if I can just some heat to get it to cure
qualitys is offline   Reply With Quote
Old 11-10-2012, 11:39 PM   #5
sdsester's Avatar
What kind of caulk? I thought you might be a troll and the moderators will check for IP address. Sorry if not.
Old 11-10-2012, 11:48 PM   #6
STAFF
BigJim's Avatar
69.81.24.50 is from United States(US) in region North America
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Tags
bath and shower, bathtub, caulk, caulking, shower
Shower Pan Question SER56 Kitchen & Bath Remodeling 6 03-22-2012 01:29 PM
Tiling a Shower thinset question Dangchores Tiling, ceramics, marble 3 03-01-2012 04:04 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 06:09 AM
AAV Shower Question PADIY Plumbing 8 01-20-2009 05:49 PM
Shower Arm Question brakea Plumbing 2 01-02-2009 06:58 PM
