Re-bedding A P Trap WC Which Is Wobbly. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 10:32 PM   #1
Re-bedding a P trap WC which is wobbly.
Hi there, I installed a new WC on the weekend on a tiled / concrete floor. Now installed the WC still rocks a little. If I were to remove the pan etc, do I need to cement it in or can I use a circle of sealant to bed it on? Thanks for listening.
mark_coulter is offline   Reply With Quote
Old 05-18-2011, 06:40 AM   #2
DIY staff
Rewards Points: 7,174
Pull the toilet again---temporarily set in place without the wax ring---use toilet wedges to get it level--
Lift toilet off and reset with a new wax ring----trim wedges---caulk in the wedges so they stay put--done--
Old 05-18-2011, 08:31 AM   #3
Rewards Points: 5,336
Is the toilet flange screwed to the floor? If it is and it's just the toilet rocking on an unlevel floor, shimming(plastic) as Mike suggests should do the trick.
Ron
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
