Range Hood Electrical - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-07-2014, 04:47 PM   #1
Rewards Points: 53
When planning on the electrical for the range hood I'm the kitchen, where should the electrical box be? (Usually) I'm planning for a wall mounted with chimney, not an under cabinet style. Are these usually hardwired, or plugin? Also, what circuit can this be on? Dedicated? I'm planning on having the microwave and the range itself on one circuit... It will be a gas range, so I only need the electrical for the ignition system... That should be ok alongside the microwave branch, correct?
I might as well ask this too... If I'm planning on all new electrical in the kitchen remodel... Should I wire (another dedicated branch) for an electric range incase I ever decide to switch from gas to electric?
Thank you!
altc81 is offline   Reply With Quote
Old 10-09-2014, 09:44 AM   #2
47_47's Avatar
Rewards Points: 44
Really need to decide on a specific make / model and follow the manufacturer's requirements. One's I've looked at are hardwired and usually connected to a junction box mounted at the top on the right hand side.
47_47 is offline   Reply With Quote
Installing a range hood with existing ductwork dave.vp HVAC 2 11-10-2012 01:41 AM
Venting Range Hood - Straight Up? Thadius856 Remodeling 4 08-05-2012 01:37 PM
electrical connection for zephyr range hood. darsunt Electrical 7 12-13-2011 12:03 PM
Range hood installation problem Lucas718 Appliances 4 08-16-2010 02:28 PM
Installing Range Hood and Stainless Steel Backsplash oguevarra Remodeling 1 02-26-2010 05:01 PM
