Quick Question About Slide In Oven/stove Opening Between Cabinets? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-22-2014, 01:53 PM   #1
Rewards Points: 209
Quick question about Slide in Oven/stove opening between cabinets?
Hey guys I have someone installing cabinets.
For an Island we have a standard 30 inch (29 7/8") slide in oven
I was just wondering how big the opening should be? I measured about 31.25 inches. Isn't that a little big?
crayola110 is offline   Reply With Quote
Old 01-23-2014, 12:44 PM   #2
K&B Designer
Live_Oak's Avatar
30". Otherwise the flanges that cover the cabinets won't do it well, and there will be too much space between the range and cabinets on the sides.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
crayola110 (01-23-2014)
Old 01-23-2014, 12:48 PM   #3
Rewards Points: 209
Thank u.
So just to confirm: a 30 inch opening would be better for the Slide in Range? that would leave a 1/16 gap on each side since the Range is 29 7/8 inches
They haven't put in the granite yet, but the cabinets are spaced 31 1/4 inches
Old 01-23-2014, 01:02 PM   #4
K&B Designer
Live_Oak's Avatar
All slide ins are designed to go into a standard 30" range space. Be sure your stone fabricator understands how to create the flat edge adjacent to the range that it will need to fit snugly. That's not usually an issue if you are getting a pencil or roundover edge, but it will be an issue with a more decorative edge like an ogee.
The Following 2 Users Say Thank You to Live_Oak For This Useful Post:
CENTERLINE MV (01-23-2014), crayola110 (01-23-2014)
Old 01-23-2014, 01:17 PM   #5
Rewards Points: 209
Oh I see Live Oak. Thanks for the info!
Old 01-23-2014, 01:24 PM   #6
Professional
TotalHomeworx's Avatar
You can have the installer add 5/8 fillers on each side of the range and the counter top should be cut to fit.
TotalHomeworx is offline   Reply With Quote
The Following User Says Thank You to TotalHomeworx For This Useful Post:
Old 01-23-2014, 01:57 PM   #7
Rewards Points: 209
Oh I see maybe that's what they're doing I am going to discuss it with him later. appreciate all the tips
The Following User Says Thank You to crayola110 For This Useful Post:
oh'mike (01-23-2014)
Quick question with cement board and underlayment supastar1568 Flooring 7 01-05-2012 06:03 AM
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 06:33 PM
Quick outlet question RodBarney Electrical 5 08-20-2011 01:06 AM
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 01:18 AM
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 11:02 PM
