Question About DensShield - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 03:04 AM   #1
Question about DensShield
The DensShield is up around the tub/shower enclosure. Do I need to fill the seams with thinset and wait for it to dry and than apply the backerboard mesh tape and apply more thinset to mesh tape? Or can I use only RedGuard and mesh tape?
Not sure what is the right process. I thought i knew how but now I'm not so sure. I thought I'd ask first so I can do this right
Philj is offline   Reply With Quote
Old 03-31-2011, 04:30 PM   #2
Rewards Points: 5,336
The website of the manufacturer would be my source for information.
Ron
Old 03-31-2011, 05:29 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Whatever you do - don't do it that way.
That method will only create humps that you won't be able to deal with and the tiles will teeter and have lippage.
I would apply the tape then apply an abundance of liquid waterproofing. The tape will develop many pinholes as the waterproofing dries so at least one more application of waterproofing will be required. This assumes the joints are tight. If there are gaps from mis-cuts or misfits then fill those gaps with thinset but shave it off cleanly on the surface of the board. Then later tape and waterproof the seams. Also waterproof the fastener penetrations. Best to use a dry paintbrush first to clean any powder out of the screw holes that exists there.
I tape and thinset all corner junctures. The build up of thinset in the corners won't have any effect on the tile placement.
I have no idea what Denshield advises for addressing the seams but as far as I know the above method works just fine.
XXX
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
