Putting In Tub Surround With A Window - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 09:52 PM   #1
putting in tub surround with a window
I am wondering what the best option might be to put a tub surround around a tub that has a window. I am looking to replace the window with a vinyl window unless there is a better option. I dont want to use glass blocks or anything like that. I plan to use cement board on all walls but am not sure the best way to water seal the window and surrounding area. Any suggestions are much appreciated.
diynoob30 is offline   Reply With Quote
Old 11-26-2012, 09:58 PM   #2
Rewards Points: 12,882
Best thing to do is get rid of the window totaly, reframe and just have a transom window. or add a solor tube. It's amazing how the whole room can light up with one solor tube. You can even get one with a light in it to use at night.
If you insist on keeping the window get a vinyl replacement window and replace all the trim with vinyl and seal all the trim behind it with silicone caulking.
Old 11-26-2012, 10:04 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
When you say "tub surround" are you saying tile or plastic?
XXX
Old 11-26-2012, 10:06 PM   #4
Trying to do this on a pretty restricted budget, so plastic is unfortunately the option.
Old 11-26-2012, 10:06 PM   #5
Just so you know, you can get acrilic block replacement windows.
Still get the light but no one can see in.
Old 11-27-2012, 12:28 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Just to clarify - I think we're all assuming when you say "tub surround" you mean tub/shower surround.
If it's just a tub it will be a whole lot easier.
Old 11-27-2012, 12:32 PM   #7
Your assumptions are correct, its a tub with a shower surround
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
Putting a door where this window is ..... CoconutPete Remodeling 23 09-19-2012 11:33 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
