Putting In Tub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 07:18 AM   #1
Putting in tub
I am putting in a new tub and it is about 1/8 inch to long. Should I notch some of the stud out to make it fit? Any help and ideas would be great. Thank you.
Mike
mjs1015 is offline   Reply With Quote
Old 04-02-2011, 07:39 AM   #2
What is the tub made of? You may be able to just trim the the tub itself. If you can't then you may have to cut into the studs. But to drop the tub in you will have to go up the wall a good three feet or so. Good luck!
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 04-02-2011, 10:26 AM   #3
Rewards Points: 5,336
Rick
You do not want to trim the tub.
What sort of advice is that?
Ron
Old 04-02-2011, 10:28 AM   #4
Thanks guys but I ended up trimming the wall studs and it fits. Thank you for your replys
Old 04-03-2011, 06:41 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
trim the tub.....what a hoot. lmao
12penny is offline   Reply With Quote
Old 04-03-2011, 06:46 AM   #6
I work for a bathroom remodeling company, and the tubs that we use are able to be trimmed. Do it every day fellas.
Rick
Old 04-03-2011, 07:24 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
sorry....just sounded funny. I've installed a fair amount of tubs myself and I dont think I've ever considered trimming the tub.
I have few questions though. What tool do you use to trim a tub? How much can you trim from a tub and are these special trimmable tubs you use?
Learn sumthin new everyday.
TIA
Old 04-03-2011, 07:58 AM   #8
The tubs we use are made of 1/4" acrylic and are cut with a jig saw. Most of the time a trim is required it is only 1/8" to 1/4". This excess is taken from the flange used to fasten the tub to the studs. Obviously, no one will have the option of trimming a cast iron, or steel tub, but with certain tubs it is an option. The only major thing to consider when carving into the studs instead of trimming the tub is recessing the tub too far. The wall of choice to be installed after the tub will need at least a little of the tub rail to sit on.
Rick
Old 04-03-2011, 08:15 AM   #9
Rick
Still think it's a stupid idea. Just because you can cut into a plastic tub, doesn't mean it should be done.
The fact you need to do it "every day" is more then a little disturbing. Feel free to list any tub manufacturer that has a cutting scenario in their installation instructions.
Ron
Old 04-03-2011, 08:35 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
. ....so if you cut the flange off, how do you attach it to the wall framing. And isnt the lip also there to prevent water from going into the wall.
Old 04-03-2011, 08:42 AM   #11
Sorry for starting a little dispute here lol. I have another question. On the one side of the tub and wall (I got a kit) the flange sticks out past the wall. I don't want to cut it off because I want to attach it. Should I just put a 2x4 there? Ill attach a picture. Thanks guys.
Old 04-03-2011, 08:56 AM   #12
Not so new
12penny's Avatar
Rewards Points: 520
....you're going to have to do something. Cant leave it that way. Add full length 2x4 or maybe 2, it sticks out there pretty far. Wrap with something moisture/mold/mildew resistant. I'd replace the rotten studs too.
And theres no dispute. Its a matter of ethics.
Old 04-03-2011, 10:33 AM   #13
Isn't this tub supposed to be supported on all three sides with a cleat?
Ron
Old 04-03-2011, 08:54 PM   #14
Rewards Points: 183
Ron
A lot of the new plastic tubs dont use a cleat. All they require is to be set in mortar and then nail the flange to the studs. Thats the way the kohler sterling tubs are installed.
usually the steel tubs use a cleat.
paul100 is offline   Reply With Quote
Old 04-03-2011, 08:56 PM   #15
Yeah the directions didn't say to use a cleat. It was a farely simple installation. Thanks for all your replys I appreciate it.
Building platform for indoor putting green jwolf02 Building & Construction 1 11-23-2010 08:32 PM
Drywall trouble when putting in can lights ritzambi Drywall & Plaster 12 05-19-2010 08:27 PM
Putting a gas line in cement slab wskiarea Remodeling 2 03-26-2010 06:59 PM
putting up car shelter mudpaws Building & Construction 1 04-27-2009 10:32 PM
putting in new service tracy Electrical 4 12-30-2008 10:18 AM
