Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 12-27-2008, 07:39 AM   #1
putting tile in bathtub wall
im removing a fiberglasstub surround and want to a regular tub and tile the wall of tub.can i use greenboard down part of the wall and then butt 1/2 inch backerboard up to the greenboard for just the area im tiling. im not going to put tile up to the ceiling just at the height were the old surround came out. and if i can do that how do i fill the gap between the to boards?
lineman8 is offline   Reply With Quote
Old 12-27-2008, 12:39 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
First of all, greenboard is an obsolete material. Doesn't do anything better than regular drywall in a bathroom.
But to answer your question, yes you can use wallboard and then meet up with the 1/2" cement board. You'd tape and drywall compound the seam just like any other wall joint.
However, may I make a suggestion? First of all, look at this thread:
http://www.diychatroom.com/showthread.php?t=31645
If you're interested in finding out a better method, let me know.
Angus
angus242 is offline   Reply With Quote
Old 12-27-2008, 04:55 PM   #3
thank you. ive decided to hire it done.
Tile Cutter vs. Tile Saw jamiedolan Flooring 8 11-09-2008 04:17 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
bathroom wall tile TonyD Remodeling 5 04-09-2008 08:55 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
Granite Tile ....on wall ? mahjohn Building & Construction 7 03-01-2006 08:55 PM
