I'd like to put beadboard in a bathroom, but I'm worried about the moisture ruining what I install. Thought about MDF because it shouldn't expand and contract, but how will it handle the moisture in the air?
I'd like to use something 1/4" tongue and groove, rather than have to mess with large sheets. Is there something that is more recommended for this type of project? I also thought about using vinyl, but I don't care for how it looks and you can't really paint it. Any thoughts or ideas on this? Would the 1/4" T & G MDF be ok.. or would I be replacing it in a few years?
Joe, thanks for the advice. The exhaust fan will be on it's way.. but probably not until spring or summer.
I have no problem using this if it will solve my concerns about moisture. After priming it carefully, you just glue it to the drywall and anchor the edges with staples? Also, what do you do for the cap and base?
You first snap a level line at the desired height where the panels going to sit. (make sure to account for the 1/2")
Mark where the studs are just above it with small pieces of blue tape.
Make a mark in the center of the panel at the top, and on the wall on the stud closest to the middle you can.
Apply the glue in a square on the outside edges about 2" from the edges and a couple of lazy S's in the middle.
Set the piece on the line and staple at the top of the panel about 1/2 down from the top.
No staple along the top working out to the edges. (Do not staple the two ends yet)
Use a rolling pin to roll across the surface of the panels to spread out the glue behind the panel.
Now staple in one of the beads on the ends and at the bottom about 1/2 up.
There should be no need for staples in the field.
The base and cap moulding will hold it to the wall.
The two end pieces need to be custom cut and scribed in. Done right there should be no need for inside corner moulding.
Over the years, mdf will swell at the edges and paint will peel. But I did use mdf door trims in a exhausted bath. Cut ends were sealed with caulk. No way near the water and no problems.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
