Puttin In Tile Around Toilet Flange - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 11:18 AM   #1
Rewards Points: 150
Puttin in tile around toilet flange
Ok. I have never put tile down before. I probably would have laid the pattern differently had I though ahead. I need to know if what I am doing will turn out ok. When I cut the tile so it would go around the flange I cut a bit more than I expected.
I haven't applied the thinset yet. I just put the tile in. However I have put in all the surrounding tiles already.
The back wall is to the right of the flange, sink cabinet to the left, another wall on the right.
klmeenan is offline   Reply With Quote
Old 09-06-2011, 01:07 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You're fine GO FOR IT as is.
XXX
Old 09-06-2011, 01:08 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Come time to grout be sure to place some duct tape over those long holes in the flange plate so you don't get grout in there. The pedestal bolts must be able to travel in those grooves.
XXX
Old 09-06-2011, 03:34 PM   #4
Rewards Points: 150
Thanks Bud!! I can start breathing now.
Old 09-06-2011, 04:00 PM   #5
amuffly's Avatar
looks fine, toilet and grout will cover that.
amuffly is offline   Reply With Quote
Old 09-06-2011, 04:10 PM   #6
Rewards Points: 150
ugh
I almost dont want to have to say this, but the bolts for the toilet arent going in where the long lines/holes are. They are actually in already, you can see the tip of the one at the bottom of the picture near the bag of grout.
Old 09-06-2011, 04:28 PM   #7
Rewards Points: 150
Here is another view. You can see that the cabinet is to the left with a wall at the back and on the right.
Old 09-06-2011, 04:35 PM   #8
Rewards Points: 150
Closer view so you can see the bolts
The Following User Says Thank You to klmeenan For This Useful Post:
The kitchen man (09-07-2011)
Old 09-06-2011, 04:39 PM   #9
DIY staff
Rewards Points: 7,174
I sure hope those bolts are long enough----looks kind if short from here---
Old 09-06-2011, 04:45 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'll bet the bolts are too short, that's what I see also.
Why is the flange installed the way it is?
XXX
Old 09-06-2011, 04:47 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The bolts that are there...
are they bolts with heads (underneath) or are they studs?
XXX
Old 09-06-2011, 08:15 PM   #12
Rewards Points: 150
they are shaped just like they should to go in the lines that they didnt use because they put it in sideways apparently.
The bolts are the ones that originally were on the toilet
Old 09-06-2011, 08:18 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well crap!!!
Oh well, see if they are in fact too short first then if they are you'll have to deal with it at that time. Your options are sorta' limited.
XXX
Old 09-06-2011, 08:21 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
On second thought...................
Go measure your pedestal and then measure the bolt exposure you have before you go any further.
You may have to take them suckers out now before you grout. One will come out easily the other you'll have to work with a bit.
Then later you can use a studded bolt, they have a wood screw thread on one side and a machine thread on the other. Can't think of what they are called right now.
XXX
Old 09-06-2011, 08:31 PM   #15
Hey bud, is it okay to have that flange situated where the tile is actually right underneath the flange? How much height can the flange be above the tile and still allow the toilet to seat correctly. My tile will be butting up to the bottom of the flange.
MarineCorpsman is offline   Reply With Quote
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 08:34 AM
New toilet doesn't sit flush on new tile toycosm Kitchen & Bath Remodeling 6 05-12-2011 07:25 AM
toilet flange installation rcassidy Plumbing 1 11-17-2010 02:12 PM
someone installed tile over my toilet flange! Emergesunscathe Flooring 3 10-13-2010 01:44 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
