Preparing Bathtub Surround For Tilings - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 01:01 PM   #1
Preparing bathtub surround for tilings
Completely gutted my bathroom and have some questions about rebuilding the bathtub surround. I am going to use Durock NextGen backerboard and Versabond white thin set.
1. I plan on tiling the ceiling over the tub. It previously had a dropped ceiling over the old tub that I ripped out, so I now have an 8' ceiling, but I have put up new sheetrock over the entire ceiling of the bathroom. Should I rip out the sheetrock over the tub, where I will tile, and replace that with Durock as well?
2. Durock indicated that I should only put up a vapor barrier on the outside wall, not on the interior walls. I forgot to ask about the ceiling, but I assume that would be considered an "outside wall" as well, which I can do assuming I need to take down the drywall as per question 1. But I have installed insulation as a sound barrier on one of the inside walls. I am thinking I should protect the insulation as well using a vapor barrier.
3. Durock also indicated not to use Redguard, but I see lots of sites recommending it (or something similar), over CBU and the Versabond white thinset should have no problems adhering. Is there a strong reason to not use the Redguard.
bfoglia is offline   Reply With Quote
Tags
cbu , cement board , durock , redguard , surround
Preparing bathtub surround for tiles bfoglia Plumbing 2 05-25-2012 07:24 AM
Question on Bathtub surround and floor Tile Install veesmack323 Flooring 15 02-27-2012 04:01 PM
Ceramic Tile around a Surround Bathtub that has been cut LittleRascals Flooring 1 10-03-2011 01:12 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
