Possible To Coat Or Seal A Tile Floor In A Stall Shower? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 10:44 PM   #1
Possible to coat or seal a tile floor in a stall shower?
Hi all. I have a standup shower stall from the late 1950s with a tile floor. The tiles are very small and easily get mildew buildup in all of the grout areas. The stall is about 3.5ft sq.
Is there anything I can coat the floor tiles to essentially make it one large smooth surface with no seams. Except for the drain in the middle?
I was curious to know if there was some type of epoxy product or other type of sealant or coating I could apply?
Redoing all of the floor tiles or all of the shower tiles is not an option now for financial reasons.
Also, if there are any such coatings I could apply, are there any drawbacks to using them? Are they easy to clean? How long do they last?
The tile I would be coating are ceramic tiles. I can try to post some picsif it would be helpful.
Thanks for any input!
Jeff DIY is offline   Reply With Quote
Old 08-25-2009, 06:18 AM   #2
If the grout is constantly having mold issues, I would cut out the old grout and regrout. Consider an epoxy grout. They are very difficult to work with and you have a limited time to work. Once it sets, that is it, you are done, whether finished or not. But it will not have a mold issue. Even with standard grout, a weekly cleaning with a bleach type product should keep things clean.
Old 08-25-2009, 04:24 PM   #3
Rewards Points: 4,578
i'd remove the tile & resurface w/decorative polymer-modified conc that's a seamless floor,,, then, if i felt like it ( OR my bride, nagzilla, insisted ), i'd scribe grout lines in it.
Old 08-26-2009, 11:56 AM   #4
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Bwaaaahaaaa! Nagzilla. Give her a big smooch for me!!!
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 08-26-2009, 03:14 PM   #5
coincidentally to this thread, 1 of the eliteCreters is posting the same topic in that forum,,, the convention wisdom is either my suggest'd method OR scarify the glaze from tiles, coat w/epoxy, broadcast aggregate to rejection, & proceed w/o'lay,,, i prefer mine as its less expensive eliminating the cost of epoxy,,, its also easier to maintain the drain's required slope just my $.03
Old 08-26-2009, 11:29 PM   #6
Thanks for the suggestions everyone. I'll look onto all of those options.
@itsreallyconc: can you post a link to that other forum? I'd be curious to read what they are saying as well.
Old 08-27-2009, 06:38 AM   #7
A quick thing to try fisrt.......thoroughly clean the floor with Comet w/bleach, flush, let dry completely, than appy one of the silicone grout sealers. Cost about $10. Simple and quick, and if it works, your are done, at least for a while.
Old 08-27-2009, 10:45 PM   #8
Thanks Bill. That sounds like a great suggestion.
Old 08-28-2009, 06:51 AM   #9
hth http://concretelocator.yuku.com/directory
Tags
bathroom , coating , sealant , tile
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
Shower stall question... Alan Remodeling 1 05-31-2006 06:57 AM
tile shower help Atricaudatus Remodeling 13 04-01-2006 08:38 PM
