Poor Installation Of Granite Counterops In Kitchen - New Construction - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 11:49 AM   #1
Poor Installation of granite counterops in kitchen - new construction
We recently had ~90 sq. ft. of granite installed in the kitchen of our new home and are not happy with the installation. There are several issues/concerns. (see below) My question is if we should allow them to dry sand the edge profile onsite or have them remove the countertops and start over.
Issues/Concerns
1.) Location of seams. There are several concerns in this area. We have a raised bar than is longer than the granite slab. Since the bar ends in a wall on one end, I expected the seam to be placed near the wall but it was placed in the middle (lengthwise) of the bar. In the location of the seam, the granite is not the same thickness so there is an obvious step in the bottom side of the granite. The top is relatively smooth. Also, there will be a cooktop stove set on the granite and instead of making a cutout and rodding the granite, they just placed a 2 inch wide piece of granite in the front and back side of the cooktop. This results in a seam in all four corners of the cooktop. These four seams are all not level or smooth.
2.) The cutout for the sink does not match the sink profile. There are several locations where the sink is recessed from the polished granite edge and only a couple places where the sink and polished granite edge match properly. (basically the sink cutout is undersized)
3.) Finally, we were not given the edge profile that we requested and was clearly listed on the work order. After installation, we were told that they didn't offer the edge that was listed on the work order. We asked for a half bullnose edge and were given a 4-5cm double radiused edge. I was never called to explain that they couldn't give us what we asked for and given my other options.
To this point, I've been offered 10% off the total cost which I have declined. They have mentioned dry sanding the proper edge onsite but stated that it would be a custom edge for them. Given their workmanship to this point, I don't think I should allow them to display any additional craftmenship. I have asked them to take the granite back out and do the job properly.
And this wasn't a discount granite installer. We made the selection based upon research and referrals. Any suggestions would be greatly appreciated.
wrocky32 is offline   Reply With Quote
Old 06-25-2012, 12:21 PM   #2
Rewards Points: 12,794
Post some pictures.
There's nothing anyone here can do about it except give some opions.
Old 06-25-2012, 12:23 PM   #3
Where are you located?
CopperClad is offline   Reply With Quote
Old 06-25-2012, 01:05 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Write a letter to the owner or president of the company.
- Build Well -
Old 07-06-2012, 08:09 AM   #5
I will add some photos of the job over the weekend. I'm located in Iowa. I have been in discussions with the owner of the company regarding the options available at this point. They have offered to come in and machine the proper edge on site but I'm concerned with dust getting into our brand new geothermal HVAC system as well as cleaning up fine dust everywhere in the house. My wife is also concerned with the walls and cabinets getting damaged as they try to change the edge profile close to the walls/cabinets. I have offered to pay for the material cost (no labor) but we haven't reached an agreement yet.
Old 07-06-2012, 06:33 PM   #6
Craftster
ghostlyvision's Avatar
Rewards Points: 95
Grinding the edge (and getting dust everywhere) is not going to fix the poor sink cutout or the many-seams cooktop area; if it were my kitchen I would request a do-over, there's just no way to fix on-site all the problems this installation seems to have.
ghostlyvision is offline   Reply With Quote
Old 07-07-2012, 09:10 AM   #7
Rewards Points: 140
take a LOT of pictures ! and i hope you paid with a credit card(if so, call them and explain). and/or. if you didn't pay yet, tell the owner/boss that you are not going to pay. and will have someone else redo the counter. if you have already paid without a credit card, you may already be screwed = they are stringing you along waiting for you to just give up.
Fix'n it is online now   Reply With Quote
2 Bathrooms and a Kitchen KevinACrider Project Showcase 16 10-31-2011 07:03 AM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 06:05 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 08:32 PM
New granite in existing construction, I want to keep my backsplash nam11b Building & Construction 5 04-15-2009 02:50 PM
New construction + vinyl kitchen removal pburgh Flooring 5 03-25-2006 03:53 PM
