Poly Or Redgard For Shower Vapor Barrier ? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-02-2009, 08:25 PM   #1
Poly or Redgard for shower vapor barrier ?
I am redoing a small shower with ceramic tile and a Noble brand built in niche for shampoo and soap, and am undecided on what type of waterproofing to use under the cementboard. What is the best method ? Polyethelene sheeting under or the Redgard over the cementboard .Thanks for the input. Tim.
tmbrink is offline   Reply With Quote
Old 01-02-2009, 09:06 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Waterproofing OVER the cement backer is the way to go. Once water gets behind the backer, what can you do about it? Best to keep moisture INSIDE the shower!
Make sure you follow the RedGard instructions carefully. Double or even triple coat the corners.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-13-2009, 03:23 PM   #3
this Redgard stuff sounds pretty awesome. yet another reason i love this forum. i had never heard of the stuff. granted, i dont know very much about construction in the first place, but i am learning.
thanks.
gregdonovan is offline   Reply With Quote
Old 06-13-2009, 03:50 PM   #4
Rewards Points: 5,336
You can also use a product called Kerdi to waterproof the walls.
Ron
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 08:29 AM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 09:54 PM
water base poly over oil base poly pappabear Painting 3 08-24-2007 02:53 PM
Poly interior doors gregrice Painting 4 05-15-2006 01:35 PM
