-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Poly or Redgard for shower vapor barrier ? (http://www.diychatroom.com/f80/poly-redgard-shower-vapor-barrier-34942/)
tmbrink 01-02-2009 08:25 PM
I am redoing a small shower with ceramic tile and a Noble brand built in niche for shampoo and soap, and am undecided on what type of waterproofing to use under the cementboard. What is the best method ? Polyethelene sheeting under or the Redgard over the cementboard .Thanks for the input. Tim.
angus242 01-02-2009 09:06 PM
Waterproofing OVER the cement backer is the way to go. Once water gets behind the backer, what can you do about it? Best to keep moisture INSIDE the shower! :thumbsup:
Make sure you follow the RedGard instructions carefully. Double or even triple coat the corners.
gregdonovan 06-13-2009 03:23 PM
this Redgard stuff sounds pretty awesome. yet another reason i love this forum. i had never heard of the stuff. granted, i dont know very much about construction in the first place, but i am learning.
thanks.
Ron6519 06-13-2009 03:50 PM
You can also use a product called Kerdi to waterproof the walls.
Ron
