Plywood Under Countertop? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 05:54 PM   #1
Plywood under countertop?
I am currently building an island for our kitchen and would like to have it ready to install a countertop. The island will be 6.5 by 4 feet, and will have 2 stools (one at end and the other at corner along the long side). There will essentially be an "L" shaped opening, with about a 2 ft overhang next to wine fridge (see pic). Please note that I am not done framing the island (ie. there will be more support), but the overhang next to fridge will be the same. Also, I will have much beefier pillar supports. We are not sure what we are going to go with for the counter, but it will likely be granite or quartz. My question is, will I have to install plywood under the counter? I am guessing yes with the overhangs..but if so, what size plywood? 3/4?
markley is offline   Reply With Quote
Old 06-03-2013, 06:35 PM   #2
bubbler's Avatar
Rewards Points: 256
When I had my countertops done (the Samsung solid surface stuff) the people who were supplying the countertop also supplied the plywood base needed.
So basically I just had a series of base cabinets sitting there, then they measured w/ a camera and some paper "targets"... a week or so later they showed up with plywood and countertops all ready to go...
So I'd check w/ whoever is providing the countertop first...
My advice is based on anecdotal knowledge or personal experience. I'm not a professional no matter how matter of factly I may say something
bubbler is offline   Reply With Quote
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-25-2011 12:58 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Kitchen plywood countertop glue? ohman Flooring 5 06-24-2009 02:52 PM
Plywood under quartz countertop? kbrinton Remodeling 5 04-11-2008 08:04 PM
