Plumbing Vent Drilled Into Load Bearing Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 03:25 AM   #1
Plumbing Vent Drilled into Load Bearing Wall
My contractor drilled a huge hole into the double top plate and bottom plate of an interior load bearing wall to accommodate a toilet vent pipe for my remodel. Looking at the size of the hole I'm concerned (he drilled through 90% of the wood), but he swore to me that it would not compromise the integrity of the house. Does this need to be reinforced? Is there anything else I should do before he puts the walls up?
Gilver is offline   Reply With Quote
Old 07-13-2013, 05:29 AM   #2
DIY staff
Rewards Points: 7,174
Removing a section of the top and bottom plate will seldom effect the strength of the wall.----the studs are what is holding up the house---if the joists are above and below the studs,then you are fine.
ben's plumbing (07-13-2013)
Old 07-13-2013, 07:40 AM   #3
Rewards Points: 13,748
Make sure there's nail plates over that area so someone does not run a screw or nail through the pipe.
oh'mike (07-13-2013)
Old 07-13-2013, 08:07 AM   #4
Thank you both for your responses- and great tip Joe Captain. I didn't consider that potential nightmare!
Need help with load bearing wall removal... Huggins90 Building & Construction 2 01-24-2013 08:06 AM
Load bearing wall load points KCK44 Building & Construction 6 11-05-2012 08:34 PM
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 05:35 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
