Plumb Studs For Tub Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 08:12 PM   #1
Plumb studs for tub surround
So I have read that sistering a stud is a good way to get your walls true, specifically for tile where you want a flat-as-possible surface.
But how do you deal with the crown of the lumber? I mean, no lumber will ever be perfectly straight. Thoughts / experience / wisdom? :-)
jdt141 is offline   Reply With Quote
Old 01-22-2011, 08:43 PM   #2
DIY staff
Rewards Points: 7,174
Always get the straightest studs for a tiled wall--Pool cue straight.
No crown if you can do it---I often have to buy 10 footers to find straight studs--the longer studs are usually cut from larger trees and are stronger and straighter.
If you must use crowned studs belly out--I guess--on second thought--you will hate tiling any thing but a flat wall.---Mike---
Old 02-01-2011, 12:12 AM   #3
Best way is to find straight studs but if your dealing with hockey sticks then the best ways I have found are cut about 2/3 the way thru the stud at the center of the crown with a sawzall and push the stud back in the wall then brace it to keep firm. Then the other way I do it (depending on how many) I snap a chalk line on the 2x4 and cut it with a skill saw.
proremodel is offline   Reply With Quote
Old 02-01-2011, 10:49 AM   #4
If the studs are plumb and crowned towards the bath a cheap electric planer does the trick.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
shimming studs for tub surround blzbub Kitchen & Bath Remodeling 7 09-18-2010 12:20 AM
Repairing Out of Plumb Non-Flat Walls Tom5151 Building & Construction 1 12-01-2009 01:48 PM
attaching tub surround directly to studs? upslims Building & Construction 11 04-07-2009 10:39 AM
Attach Shower Surround to Studs on Outside wall? BillyDIY Plumbing 2 08-25-2008 02:09 PM
