Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 06-13-2011, 11:08 PM   #1
Unhappy
Plastic shower base and concrete / leveling issue
Noticed shower stall base not level inside (frame of base is level) AFTER remodelers were done with job. The ("plastic") shower base was set into wet concrete and a marble floor installed a few days later. Now when one takes a shower the water pools because the drain is pretty much the high point in the floor. You have to squeegee or move the water into the drain. My dilemma: is there ANY way to drill a hole on either side of (or anywhere on) the base and fill with concrete and let it dry and thereby raise/level the inside floor of the base??? Realllly don’t like standing in water when I shower… but will deal with it if it means tearing out everything. (NOT an option.) Thank you ahead of time for not making fun. LOL
JoTeeBee is offline   Reply With Quote
Old 06-13-2011, 11:16 PM   #2
Tileguy
Bud Cline's Avatar
You are stuck with it. There is only one way to fix that and you have already torpedoed that idea. How old is this shower floor? Shouldn't the installers be responsible for fixing the problem?
What brand of tile-base is it just out of curiosity.
Old 06-17-2011, 08:46 PM   #3
Tear it out or live with it.
Ron
B. Franklin 1759
Tags
concrete, drain, flooring, shower remodel, shower stall
How to install a concrete shower pan over dirt run2smiles Flooring 10 01-03-2013 05:49 PM
Installing acrylic shower base onto concrete floor Dawna106 Flooring 0 10-15-2010 06:42 PM
adding shower base kerbongi Plumbing 2 08-08-2010 10:07 PM
How to build base for a shower stall atm Plumbing 13 05-13-2009 11:18 AM
landscaping backyard with Pavers - needs concrete base? sundar Landscaping & Lawn Care 7 10-09-2008 08:28 PM
