Plaster Walls - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 09:31 PM   #1
Rewards Points: 28
plaster walls
can you remove tile from plaster walls sand smooth and re tile?
dmack7 is offline   Reply With Quote
Old 01-31-2012, 09:39 PM   #2
Rewards Points: 13,694
Not likly to happen without some wall damage.
Old 02-01-2012, 10:48 AM   #3
Depends on the type and condition of the plaster. Even if the tiles come off without destroying the plaster, you'll need to create a smooth, even surface to apply new tiles
mrgins is offline   Reply With Quote
Old 02-01-2012, 12:57 PM   #4
Rewards Points: 28
the plaster is like 5/8" thick that's why i was hoping to avoid demo
Old 02-01-2012, 04:05 PM   #5
is it wood lath?
Old 02-01-2012, 04:20 PM   #6
Rewards Points: 28
there was a hole in the plaster but its so thick i couldn't really tell i don't think i saw any
Old 02-01-2012, 04:31 PM   #7
Usually you can tell if there's wood lathe as it isn't very far beneath the surface. You can use a putty knife and hammer to try to tap the tiles off with as little damage as possible. If there is damage, you could cut a line from where your new tile will go, and replace that part of the plaster with backer board built out to the face of the plaster. You will need solid support behind the backer board and remaining plaster so they don't flex. You'll also need to repair any loose plaster that is left above the backerboard
Trying to Demo Thick Plaster Walls earthad1 Building & Construction 3 03-28-2011 09:43 AM
Painting Calcoat Plaster Walls Rlearn Painting 0 03-14-2011 10:51 PM
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 05:30 PM
help with plaster walls... bcbud3 Remodeling 0 06-21-2010 03:19 PM
New Wiring Behind Plaster Walls nxl Electrical 5 12-12-2009 09:31 AM
