Peel & Stick Wood Veneer...use Contatct Cement Or Not - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-23-2015, 05:48 PM   #1
Rewards Points: 6
Peel & Stick Wood Veneer...use contatct cement or not
I am getting ready to do my first project with veneer and purchased the peel and stick type and really do like the pattern of the wood grain.
This is for a 1950's dresser. Most all of the surfaces are veneer and in pretty good shape, however the top is something like a Formica. Because I am changing the color of stain to a darker finish I want to apply wood veneer on top of the Formica surface and stain it to match. (I'm working with Minwax oil based stain and polyurethane sealer) I have prepared the surface using 120 grit sandpaper as recommended but thought I would ask a couple of questions before I attempt to apply the veneer.
1) Should I use contact cement with the peel and stick veneer?
2) IF SO can someone recommend kind/brand of contact cement ?
3) I am also interested in any tips and tricks for working with wood veneer.
This isn't an heirloom piece so I'm willing to try recommendations. I just want best results possible. (I do have a few heirloom pieces that need similar repairs...I will learn on this piece first)
I would appreciate any input and information you might share. Thanks, Toni...
TAScadina is offline   Reply With Quote
furniture , peel and stick , veneer
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
peel and stick on vinyl? advice Buzzman Flooring 8 06-09-2012 05:42 PM
Grouting vinyl peel and stick tile Pnkhollie09 Flooring 2 03-21-2012 03:03 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
