Pedestal Sink For Old Bathroom? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 01:10 PM   #1
Rewards Points: 16
Pedestal sink for old bathroom?
My 1911 home's main bath has a pedestal sink installed about 15 years ago. Walls are plaster/lathe still in good condition. The sink was only glued to the wall and has come loose. The bowl is also loose from the pedestal! A wonder it functions without falling over! It does but it is dangerous and has a small leak. If I keep the sink, what is the best way to attach it safely? If I opt for a new sink and it is not pedestal, I have to deal with a 4"wide x 6-7" high wood box along the wall base which was originally built to enclose the incoming the water pipes.
mollywobbles is offline   Reply With Quote
Old 03-26-2013, 04:49 PM   #2
Rewards Points: 12,878
Got a picture?
That sink was suppost to be lag bolted to the studs or a 2 X 6 wooden plate behind the wall.
Some use a steel plate that mounts to the wall and the sink slids onto the plate.
http://www.bing.com/images/search?q=...lectedIndex=21
The sink just sits on the pedistal, it's not attached to it in most cases.
mollywobbles (04-10-2013)
Old 03-27-2013, 11:41 AM   #3
Rewards Points: 16
joecaption,
Here are a couple pics. You can see that the bowl was "puttied" to the pedestal. There was originally a large old-fashioned iron sink that was bolted to a piece of iron which was presumably bolted to the wall. That was all removed.
Thank you for the link--Very helpful!
I think the leak is just around the faucet mount. Not sure, but it's just occasional.
Pedestal sink for old bathroom?-dsc01662.jpg   Pedestal sink for old bathroom?-dsc01664.jpg
Old 03-27-2013, 02:02 PM   #4
Rewards Points: 578
If you decided to go back with something other than the pedestal you could always notch the back bottom edge to fit around the box. Cut a square out of the bottom back edge and then screw it to the wall, the box for the plumbing would then be partially hidden by the vanity. If its a small bathroom, a pedestal is probably best. I would do that in my tiny bathroom if it wasnt for the fact that there are five giant drain holes in my floor that need covered.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
The Following User Says Thank You to TrailerParadise For This Useful Post:
Pedestal sink gap between wall and sink marcus118 Plumbing 2 12-07-2012 04:33 PM
Turning off valves bathroom sink richard7994 Plumbing 3 11-28-2011 06:25 PM
How to use a pedestal sink on a vanity? Maddux Kitchen & Bath Remodeling 4 06-20-2011 11:06 AM
Retrofit bathroom vanity with above counter sink Sushijung General DIY Discussions 10 11-26-2010 02:47 PM
Pedestal Sink epolgar Plumbing 5 07-31-2007 04:21 PM
