Painting On Cement Backer Board With Screws - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-08-2016, 11:01 AM   #1
Rewards Points: 30
Painting on Cement backer board with screws
We re-installed backer board in the shower area in the ceiling.
Would like to just paint it and not tile it.
The screws are not countersinked.
Should we countersink the screws? i know most sites i read said you should not countersink backboard scews.
Any ideas to prep the board for painting? would like to have a smooth painted surface. Can we use joint compound to smooth over screws?
Any advice would help.
jcjst21 is offline   Reply With Quote
Old 06-08-2016, 01:26 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Re: Painting on Cement backer board with screws
If you are not kidding.
Counter sink the screws. Fiber tape and thinset any joints. Skim coat with thinset (textured if you like). Paint with a cement paint.
Coastal South Carolina
Old 06-08-2016, 05:34 PM   #3
KarenStein's Avatar
Rewards Points: 426
Or ...
If the bath is small enough, you can cover the entire ceiling with a single piece of "FRP," a fiberglass reinforced plastic, with a pebble texture. It's often found in commercial restrooms; available in white, almond, and grey. Attach with a contact cement.
KarenStein is offline   Reply With Quote
Old 06-12-2016, 11:06 PM   #4
Rewards Points: 18
i dont know where u live but why would you put cement board on the ceiling on ceiling. it is not getting any water from the shower. i would put green board and mud the joints and paint over the sanded finish.
but u did put cement board already just mud the joints, counter sink the screw and do a skim coat on the board 1-2 time and sand it, than paint
epsonlu is offline   Reply With Quote
Old 06-16-2016, 05:31 PM   #5
KarenStein's Avatar
Rewards Points: 426
A few more notes about your intended project ....
I see no issue with countersinking the screws - save for the way the cement board will quickly dull any countersink!
Cement board is far more moisture and mold resistant than green board. I wouldn't use green board anywhere in a shower; there's too much challenge from condensation and humidity. Indeed, one might even consider installing the ceiling at a slight angle, to encourage condensation to drain.
Some alternatives to the cement board are other tile backer boards (Denshield and Fiberock are two examples). They lack the paper face that is the 'Achilles' heel" of green board.
Ready-mixed joint compound will also support mold growth. If you're going to use a "naked" board product, you should use a "hot" or setting type joint compound and mesh tape.
After you tape and skim-coat the board, I suggest a waterproof shellac primer, topped with a gloss paint.
Plunge cut cement board - or not? miamicuse General DIY Discussions 5 11-13-2013 08:58 PM
How big, if any, should the gaps be between cement board when using for tile backer? Arsinek Building & Construction 8 04-14-2013 10:16 PM
Cement Board - Under raised porch? spaceboy Flooring 1 05-10-2012 04:14 PM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Cement backer board - which to use? manhattan Building & Construction 3 09-14-2009 03:57 PM
