-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Over the stove Microwave or tiling first? (http://www.diychatroom.com/f80/over-stove-microwave-tiling-first-46894/)
MsNotHandy 06-17-2009 04:34 PM
okay so i am installing (new installation) microwave range and also want to add slate tile backsplash. would i install microwave first then tile around it or vice o versa? i am afriad if i tile first, i would def have to drill into the tile to add mounting bracket for microwave. and slate seems like something that is going to be hard to drill into...plus, trying to locate a wall stud after adding the tile? :huh: but if i install the microwave first, might be messy? someone please give me guidance on this!
Bob Mariani 06-17-2009 09:28 PM
microwave goes in first
johnnyboy 06-17-2009 10:56 PM
What happens if you ever have to replace the microwave and the footprint is different? Retile?
Just Bill 06-18-2009 07:23 AM
The micro mounting bracket needs to sit flat. If you tile part way it will not sit flat. If you tile all the way behind, you will need to drill thru the tile for the bolts. At least two bolts MUST be in studs, so if you tile behind, mark your studs. Many undercabinet units are designed to sit flush with the cabinets. Tile will space it out the thickness of the tile.
Paragon 06-19-2009 09:20 PM
You could go either way on his one.
If you are tiling and are going to do a design in the field of the tile then you should plan where the OTR goes and installthe tile first. Also the advantage of installing the tile first is that you won't have to contend with the OTR in the way. It is easy enough to dril through the tile I always lightly score the glazing and then drill the holes with a hammer drill. Keep the drill slow until you get into the tile a bit and even then the slower the better to not crack the tiles. Also STAY AWAY FRO THE TILE EDGES when drilling!!! If you get an edge with the bit this is what cracks the tile, drill the field of the tile! You will have all sorts of holes to choose from when choosing where to put the fasteners. If you tile after you will have that OTR in your way and if it is cost you are worried about then tile the area behind the OTR with cheap tiles but I don't think that the few wxtra tiles will put you in the poor house.
Also when installing the mounting bracket you only have to have one bolt in a stud and you will find that in the installation instructions but 2 are better. The bolts with the expanders will be more than sufficient to hold that mounting bracket up and the reality of these OTR is that the cabinets really hold the majority of the weight and the bracket holds it in place, kinda, lol. Hit at least one stud and two if you can.
Here is a pretty comrehensive article I wrote for another DIY site check it out and you might find something that will be of use... http://www.refurber.com/advice/120/H...nge-microwave/
So I would install my tile first and just be careful when drilling the tiles
Good luck and be safe!
