Okay For Vanity To Be 2" From Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-07-2013, 03:16 PM   #1
Rewards Points: 384
Okay for vanity to be 2" from wall?
Some of the plumbing comes out of the floor and the vent seems to take a 45 degree angle over the corner instead of 90 so the vanity doesn't fit flush up to the backwall/corner. Is it okay to just have it sit forward about 2" assuming it doesn't interfere with the space in front? I'll just create some spacers with wood so I can attach it and then when the guys come to measure for the top everything will fit fine?
The other option (not counting redoing the plumbing which I don't want to do) would be to cut the vanity which is what they did to the old one.
RyanD is offline   Reply With Quote
Old 08-07-2013, 05:46 PM   #2
Rewards Points: 12,794
Posting a picture would be a real big help.
Is this old steel plumbing?
I can not imagine having it that far out away from the wall looking right.
oh'mike (08-07-2013)
Old 08-07-2013, 07:40 PM   #3
Rewards Points: 6,652
Not really. It needs to be square with the wall. Can you post a picture with a Carpenter's square on the wall, showing how out of square it is.
Old 08-07-2013, 07:55 PM   #4
Rewards Points: 6
You can do it. If the vanity is in the corner, do you have an end panel that will cover the additional gap? You'll just wind up with a deeper counter top which is a nice thing in a bathroom.
Dan
djlandkpl is offline   Reply With Quote
Old 08-09-2013, 07:01 AM   #5
Rewards Points: 384
It's actually not as bad as I thought, looks to be under an inch. Here are some pictures.
Okay for vanity to be 2" from wall?-2013-08-09-06.37.22.jpg   Okay for vanity to be 2" from wall?-2013-08-09-06.59.20.jpg
Old 08-09-2013, 07:54 AM   #6
Rewards Points: 582
check to see why it is out at the top...it could be the wall....if you can't do anything with it ...shim it and screw it....but check vanity top depth 1 st ...but it looks like it should be ok.....other option tear it all out and start over? ben sr
Old 08-09-2013, 08:14 AM   #7
Check the floor for level, and the wall for plumb.
I often find the floor is sagging in the center of the room causing the cabinets to tip.
Old 08-09-2013, 10:29 PM   #8
firehawkmph's Avatar
Rewards Points: 1,798
Ryan,
in the picture looking down, is the vent running horizontal across the wall? If that is that case, since your cabinets fit in between end walls, I would rip a piece of wood to take up the gap and screw it to the wall above the vent if there's room, if not, right below the bent. Fasten your cabinets to the piece of wood after leveling and making sure they're plumb. As long as you are having a countertop made up, it will just have to be a little deeper. Not really a big deal. Don't know why the vent is sticking out, but it's not really hurting anything.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
2" PVC in 2x4 Exterior Wall? stubits Plumbing 17 05-28-2012 02:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
