-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Okay for vanity to be 2" from wall? (http://www.diychatroom.com/f80/okay-vanity-2-wall-184925/)
RyanD 08-07-2013 02:16 PM
Some of the plumbing comes out of the floor and the vent seems to take a 45 degree angle over the corner instead of 90 so the vanity doesn't fit flush up to the backwall/corner. Is it okay to just have it sit forward about 2" assuming it doesn't interfere with the space in front? I'll just create some spacers with wood so I can attach it and then when the guys come to measure for the top everything will fit fine?
The other option (not counting redoing the plumbing which I don't want to do) would be to cut the vanity which is what they did to the old one.
joecaption 08-07-2013 04:46 PM
Posting a picture would be a real big help.
Is this old steel plumbing?
I can not imagine having it that far out away from the wall looking right.
gregzoll 08-07-2013 06:40 PM
Not really. It needs to be square with the wall. Can you post a picture with a Carpenter's square on the wall, showing how out of square it is.
djlandkpl 08-07-2013 06:55 PM
You can do it. If the vanity is in the corner, do you have an end panel that will cover the additional gap? You'll just wind up with a deeper counter top which is a nice thing in a bathroom.
RyanD 08-09-2013 06:01 AM
2 Attachment(s)
It's actually not as bad as I thought, looks to be under an inch. Here are some pictures.
ben's plumbing 08-09-2013 06:54 AM
check to see why it is out at the top...it could be the wall....if you can't do anything with it ...shim it and screw it....but check vanity top depth 1 st ...but it looks like it should be ok.....other option tear it all out and start over? ben sr
joecaption 08-09-2013 07:14 AM
Check the floor for level, and the wall for plumb.
I often find the floor is sagging in the center of the room causing the cabinets to tip.
firehawkmph 08-09-2013 09:29 PM
Ryan,
in the picture looking down, is the vent running horizontal across the wall? If that is that case, since your cabinets fit in between end walls, I would rip a piece of wood to take up the gap and screw it to the wall above the vent if there's room, if not, right below the bent. Fasten your cabinets to the piece of wood after leveling and making sure they're plumb. As long as you are having a countertop made up, it will just have to be a little deeper. Not really a big deal. Don't know why the vent is sticking out, but it's not really hurting anything.
Mike Hawkins:)
