Oatey Shower Drain - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 02:30 PM   #1
oatey shower drain
how tight do i need to tighten my new oatey shower drain? it just slides over a 2" abs tube and comes with a flimsey tool that you tighten with a screwdriver. you can't get it very tight because the tool just bends, but it might be tight enough? i just don't want to find water leaking under the floor. had anyone used these and have any advice?
akbeard is offline   Reply With Quote
Old 01-21-2010, 09:16 PM   #2
I will have to assume this is a no-calk drain. Tighten it up untill it's snug. My best advise would be is to check it for leaks. Any plumber worth his/her salt would double check for leaks just in case.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 12:49 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
