No Bathroom Ventilation! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 05:06 PM   #1
No bathroom Ventilation!
We recently purchased a home that has a basement. On the side where there is not outside exposure is where they put the half bathroom. The place stinks. It needs a good scrubbing but I think it also needs a ventilation system of some sort. It's tolerable if the bathroom door is left open or cracked but if you close it and go in there later you have to hold your breath!
Any thoughts on how to vent a basement bathroom with no outter wall exposure?
jen_mom6 is offline   Reply With Quote
Old 06-23-2012, 05:12 PM   #2
Is the bathroom built into the exterior wall or is it kind of in the middle?
CopperClad is offline   Reply With Quote
Old 06-23-2012, 11:47 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
If your bathroom smells when no one has been using it installing a ventilation fan, while a good idea, would be just masking a symptom not addressing the problem.
You need to figure out where the smell is coming from. The first thing I would do in your shoes is to pour water down every drain and sink in the room. This, by itself, could solve your problem. Sometimes if a shower or tub is not used, the water in the P trap can dry out and let sewer gasses into the room.
If it doesn't then you need to look further into other possibilities such as vent stack issues or hidden mold/moisture issues.
The Following User Says Thank You to Blondesense For This Useful Post:
oh'mike (06-24-2012)
Old 06-24-2012, 12:01 AM   #4
What type of smell is it? ... musty or sewage?
mkiefer is offline   Reply With Quote
Old 06-24-2012, 07:46 AM   #5
DIY staff
Rewards Points: 7,174
Last month I ran into a stinky basement bath room---Shower drain was done improperly--
Could be a lot of things---you need to do some investigation---an unused bathroom should not have an odor.
Tags
bathroom ventilation
bathroom ventilation LMPD Electrical 3 12-12-2011 02:01 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
BAD ADVICE??? You tell me! Bathroom Exhaust Fan Ventilation firefish317 Plumbing 2 04-20-2010 09:23 PM
Bathroom ventilation / window privacy issue Michael Thomas General DIY Discussions 10 05-26-2009 10:09 AM
Bathroom ventilation and cooling dragon6172 General DIY Discussions 3 05-11-2009 03:40 PM
