-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   New toilet doesn't sit flush on new tile (http://www.diychatroom.com/f80/new-toilet-doesnt-sit-flush-new-tile-103932/)
toycosm 05-08-2011 10:52 PM
I'm installing a new toilet on newly installed porcelain tile. I tested the way it sits on the tile without the wax ring, just setting in place on the foor where it's supposed to rest. The rim of the toilet base did not touch the tile; it was held up off the floor by something in the center of the base. I turned it upside down and saw that there are ribs molded into the bottom of the toilet to help support it. However, theses ribs protrude lower than the rim of the base, and prevent it from touching the floor. Can I, should I, grind or file down these ribs so they are even with the rim of the base?
[The old flange was replaced when the tile was installed. It's screwed into the backer board and is slightly higher than the top of the new tile.]
Ron6519 05-10-2011 12:19 PM
How high off the floor does it sit? If it's less then 1/4", you can caulk the space.
What make of toilet is this?
Ron
toycosm 05-10-2011 10:23 PM
Ron
The gap is less than 1/4". It could easily be caulked, but all the weight is resting on four short ribs. I'm just not comfortable with that. On linoleum, I imagine they would sink in let the rest of the base contact the floor. Unless there's a way to work down these ribs, I don't think I'll use this model (Kohler Cimarron).
oh'mike 05-11-2011 06:18 AM
Take a picture of the toilet flange---If you used a 3" inside glued flange you are in trouble----those only work if mounted flush to the floor surface,(or below)
Ron6519 05-11-2011 07:23 AM
These could be projections not cleaned off at the manufacturing plant and not spacers.
Can you take a photo of these?
Ron
toycosm 05-11-2011 10:15 PM
I took that toilet back to the store. I looked at the same model in another store, it had two of the four ribs protruding below the base rim, and the other two flush. I thinks its mfg variance. I'm not opposed to working them down if theres a safe way to do it, but I don't know anything about that material.
Ron6519 05-12-2011 07:25 AM
A grinder with a masonary composite blade would make short work of the protrusions without causing trauma to the unit. It's like sanding the high spots off a piece of wood.
Ron
