Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-10-2009, 09:00 PM   #1
New Countertops
when installing new counter tops......Is it best to turn the counter top over and make your cut from the bottom side or cut from the top? I was under the impression that cutting from the bottom is best so the counter top doesn't get chiped!!!!!!
Van6786 is offline   Reply With Quote
Old 05-11-2009, 06:57 AM   #2
New Countertops
And use a new or sharp carbide blade, circular saw, no sabre saws. Correct, there is less risk of chipping when cutting from the back.
Old 05-11-2009, 07:05 AM   #3
ccarlisle's Avatar
New Countertops
If the blade of your saw makes the cut coming up, i.e. from underneath the way a circular saw balde does, then cut from the bottom where the blade actually hits the hard, laminate plastic first (not after it cuts through the wood).
It reduces chipping - although not a major factor if the blade is sharp. Depends a bit, but that's a general rule,
ccarlisle is offline   Reply With Quote
Old 05-12-2009, 12:10 AM   #4
New Countertops
Down cutting jig saw blades are available.
Mop in Hand is offline   Reply With Quote
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 08:32 PM
Need advice/tips on tearing out old laminate countertops TumsGum Kitchen & Bath Remodeling 6 03-07-2009 10:52 AM
Opinion on countertops please... skipjack Kitchen & Bath Remodeling 11 01-29-2009 12:20 AM
Best Way To Attach Countertops to Bases? GearHd6 Remodeling 13 01-18-2008 10:41 AM
