Need Shower Pan Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 09:29 PM   #1
Need shower pan help
I have one of the most messed up showers. The drain is not centered which makes me mad but that is life. So now I have to do some thinking. This is on a cement slab so I really don't want to do any demo to the cement since I don't weigh much over 100 pounds. So what I was thinking was leaving the old walls where they are and building new ones to make the drain centered. You can see from the before picture how the bathroom is set up. Then you can see what I am taking about when it comes to the drain. Then the picture of what the bathroom looks like now. I need ideas on what base I should use, because I would like to get a pre-fab base. I don't want to deal with putting tile back in. One the picture that has the floor, you can add an inch or 2 to the 22 inches and the 18 inches. It was done like this, tile to drywall then the drywall was on top of ply wood then the studs. So Ideas would be great. Thanks a bunch and have a happy thanksgiving
Need shower pan help-sam_1242.jpg   Need shower pan help-sam_1364.jpg   Need shower pan help-sam_1641.jpg
southernmom is offline   Reply With Quote
Old 12-21-2010, 12:46 PM   #2
HomeAdditionPlus.com
Rewards Points: 29
I would leave the walls where they are and install a mortar shower pan that includes a preslope layer of mortar to direct the flow of water towards the drain. You then can put a flexible membrane liner over the pre-slope and then another final layer of mortar to finish the pan.
mjdonovan is offline   Reply With Quote
Old 12-21-2010, 04:20 PM   #3
Rewards Points: 5,336
No one has answered this woman until today?
Where was this post?
Ron
Old 12-21-2010, 05:02 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
First I've seen of it.
XXX
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
