#1 |
Need to replace two tiles on brand new wall
I recently took my bathroom down to the studs, and am now in the final steps to the process, no thanks to any of the contractors I used. Anyway...
The plumber came today to do the final hookup of the tub faucets and such, and there are two gaps in the tile where the fixtures didn't cover what I thought they would. One is around the valve, and the other is above the tup spigot. It would just be two tiles to replace, and I have plenty of them, but I'm wondering about thinset and grout. Do I need to buy another 50 lb bag of thinset and a 10 lb bag of grout to do it right? Can I use the pre-mixed thinset that comes in the tub for these two tiles? The grout I guess isn't a big deal. It's a huge waste of material, but not a lot of money or time. See my picture for my problem... Any thoughts? Thanks in advance! |
#2 |
Super Moderator
Those are soft tiles and shouldn't be to hard to remove---tap them gently and crack-em--
take them out in small pieces. As for gluing in the two new ones--I'd use clear silicone and tape them in till they dry-- As for the grout--you have no choice but to buy more of the same brand----save the left over in an air tight can. |
#3 | |
Need to replace two tiles on brand new wallQuote:
Thanks! Checked Home Depot and all I found for silicone adhesive was aquarium glue. Would some Liquid Nails work? Says it's waterproof. |
#4 |
Super Moderator
Regular old silicone caulk--100 % silicone-kitchen and bath. And yes ,liquid nails would work.--Mike--
#5 |
Thanks! One more question...well...two I guess.
The substrate is Hardibacker, and I put RedGard over it. When I removed the old thinset, the RedGard came off with it. Very cleanly, but now my waterproof membrane is compromised. Should I carefully put more RedGard over the bare spots or just run a bead of silicon around the area to re-seal it? Also, the thinset was about a quarter inch thick, so the new tiles are a little below the surface if they're directly on the wall. Should I make a bed of silicon to keep the tile even with the rest of the surface, or should I just embed some spacers behind the tile? I'm not sure what a cavity back there would do if water happened to find it's way in. |
#6 |
Super Moderator
Take a putty knife and coat the backer with a thin coating of the silicone,then put silicone on the tile
and push it into place. Have a bottle of soapy spray cleaner and some paper towels handy.I like Greased Lightning--409 works well also. As soon as you push the tile into place--spray the tile down with the soapy spray. Silicone can not stick to soap--Remove any squeeze out with your finger--soap it again and clean out the grout line Wipe clean with your towels --tape if needed. The silicone will replace the missing redguard. ---Mike-- |
| Display Modes | |
| Removing spine wall | beko | Building & Construction | 12 | 02-02-2010 02:15 AM |
| how to determine if wall is load bearing | Tonglebeak | Building & Construction | 26 | 01-21-2010 12:26 AM |
| Do I need to replace my wall panels, or can I fix them? | mspiegle | Building & Construction | 3 | 08-12-2009 12:51 AM |
| Wall - LOAD BEARING: How to Move? | user49172 | Building & Construction | 1 | 03-11-2009 05:48 PM |
| Replacing A Few Tiles On Shower Wall | EDENO | Remodeling | 1 | 12-11-2006 12:25 PM |
