Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-22-2010, 07:52 PM   #16
Tileguy
Bud Cline's Avatar
Need info on tiling around a 90 degree outside wall corner
Not a task for a first-timer. Do it however you want, maybe you'll get lucky.
I suggested the SCHEIN over the RONDEC simply because the SCHEINE provides a smaller less noticeable profile when in position.
Old 02-22-2010, 08:43 PM   #17
I will try to miter some scrap tile that I have and see if I can do it. if I can't I will try the stuff that was suggested if I can find where to buy it. Do they have it at Lowes hardware or Home Depot. I am pretty crafty, and use tools a lot. I have the determination and patience that would be needed to do it, but if it doesn't work out then I will know what to do to make it look right. Hopefully my Father and Brother in Law will be around because they have tiled before. I just wanted to do it myself. LOL Might need to call in reinforcements
Sandra
s38hyler is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
120 degree outside wall molding Bill625 Carpentry 7 10-21-2009 09:09 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
