Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-10-2012, 03:32 PM   #1
Need help setting shower drain in existing slab drain hole!
I'm planning on installing a DIY-concrete shower base in small master 3/4 bath, it will most likely be 32x32 or 34x34 depending on the boss's final say (wife) and due to size constraints.
House is on slab and there is an existing 1-3/4"ID cast iron drain pipe that is 4-3/4" below slab top and 16 1/2" to center from either wall.
My concern is the 8"x8" hole in the slab around the drain pipe, it is squared underneath the broken 1" thick 6 1/2"x7" slab "top" (have pics will try to post when I get home).
I'm not sure what to do to fill the void so that the new concrete base and drain i'm going to install will not crumble and collapse down into the void, or do I even need to fill the void?
Will the 1" preslope at drain and 1-1/4" base at drain I'm planning be strong enough to support everyday shower use? Base will be stained and sealed not tiled and walls will be tiled over 1/2" CBU.
Previously had a metal shower stall in this spot and we dont want to put a prefab pan in unless we have to, we want to install something that will last and I enjoy the feeling of pride and self worth that comes from making something with my own hands. Not sure if this the right spot to post this or if it should be in another forum but, any help would be greatly appreciated.
Last edited by deedeedeeIY; 05-10-2012 at 03:45 PM. Reason: change title to reflect needing help not giving help!
deedeedeeIY is offline   Reply With Quote
Old 05-10-2012, 03:51 PM   #2
MarginallyQualified
Originally Posted by deedeedeeIY View Post
...existing 1-3/4"ID cast iron drain pipe that is 4-3/4" below slab top
...8"x8" hole in the slab around the drain pipe...
After you make the plumbing changes required to attach a (2" pipe size) trap and locate the 2" fitting in a spot convenient to align with whatever you end up using for a shower pan... some well packed soil or even sand should be plenty enough base to pour some concrete over.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
deedeedeeIY (05-10-2012)
Old 05-10-2012, 04:02 PM   #3
the existing iron pipe is 1-3/4" ID and 2-3/8" OD (thick old stuff)...and thanks for the reply.
Old 05-10-2012, 05:36 PM   #4
MarginallyQualified
Perhaps I was being too subtle...
There is no such thing as 1 3/4" pipe and even if there were it isn't the 2" required by code (everywhere I know of) for a shower or bath drain. I also didn't specifically describe the trap and vent you'll also need.
iow... the concrete is the least of your issues. hth
Old 05-10-2012, 05:55 PM   #5
Super Moderator
You will need to open the concrete and add a modern 2" pvc drain---
Add a clamping drain to hold the membrane--and then fill the excavation with gravel and fresh concrete.
After that--use deck mud to form the preslope--add the membrane--add the Durrock for the walls--pack the base with deck mud---form the curb with fat mud---and you will be ready to tile or otherwise finish the rough base.
Old 05-10-2012, 09:48 PM   #6
thank you TarheelTerp for the post I appologize for not clarifying in my original post my plans to correct the bad existing plumbing issues, but now I know next time to just ask the question I need answered. More sand to fill in the void is just what I needed Thanks again!
Old 05-10-2012, 10:01 PM   #7
[quote=oh'mike;918847]and then fill the excavation with gravel and fresh concrete.
So sand around the pipe and drain will not suffice? Will Quikrete 4,000psi be good enough? And yes I had previously found the instructions for the concrete pan and curb here which is why I had planned to do it, I knew it was something that I could tackle, I am still on the fence as to whether I should use the membrane or RedGard on the pre-slope though, plan on it over the CBU.
Old 05-11-2012, 07:38 AM   #8
Super Moderator
Use the membrane---Redguard is no up to the task of waterproofing a pan--If you wish to use a surface paint on membrane---look at Latacretes site--Hydroban is the product.
I am building a Hydroan shower today---It's a whole different animal---Look at Latacrete---Mike---
Old 05-11-2012, 09:18 AM   #9
Thanks Mike, I'll check out the Latacrete site for the hydroban, really appreciate it.
Old 05-11-2012, 10:39 AM   #10
You should try a product called the OneLiner, I used it a little while ago for my shower and it was pretty simple to use. It comes with a kit with stuff for both mortar beds too (pre-slope and regular shower floor), drain and a curb kit too. Go to dixsystems.com to see what I am talking about. I definitely recommend it for a diy.
CrAzYDiTz is offline   Reply With Quote
The Following User Says Thank You to CrAzYDiTz For This Useful Post:
deedeedeeIY (05-11-2012)
shower drain plumbing Arrrgh! Plumbing 14 04-10-2012 10:01 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 07:28 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
New shower with existing drain jamesdcarroll Remodeling 1 02-08-2008 03:13 PM
