I am in the process of replacing the floor in the shower stall. I have removed all the floor tile and now need to remove the last row of the wall tile, without damaging the tile. I have a grout scraper, chisel and hammer, but the grout is like a solid block of cement. Is there anything I can do to help speed up the removal process? Oh and I am broke, (a teacher's life) so it has to be done with what is in the house.
I am doing this because floor tiles cracked and began to come up. Also because there is no else. Finally it's a way for me to learn and keep my brain going. If i have to loose the bottom, it will be ok. Now any suggestions?
You limited my suggestions to what you have in the house---There is no way to remove those tiles without breaking at least one on each wall---once the grout is removed-
-use a utility knife if that's what you have---you will need to pry the tiles off the backer board--that's not likely to happen as the thinset or mastic may be stronger than the tile.
You are right--if your pan has failed the first two rows will need to be removed--But seriously,unless the tile is a historic antique,it will not be worth the effort.
I will go ahead and plan on loosing the bottom row. You're right it will make my job much easier.
Thanks again!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
