My Bathroom Remodel- First Time - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-20-2014, 10:49 AM   #16
Thanks for the reply! Those receptacles in that last pic is already existing. Old stuff.
I am replacing the old switches and gfci outlet with newer products. But I wont be running new wire. Thats what the builder put there.
tcoche is offline   Reply With Quote
Old 05-20-2014, 09:58 PM   #17
Rewards Points: 956
is the ceiling still in place?
federer is offline   Reply With Quote
Old 05-20-2014, 10:11 PM   #18
Yep! I didnt see anything wrong with the ceiling drywall at all, other than the nasty yellow color.
I am a one man team here. I really didnt want to have to deal with the insulation and getting help to hang new drywall. I am happy I didnt have to go down that road.
I did purchase 2 shower rated recessed lights I am adding to the ceiling for the shower.
Old 05-24-2014, 07:44 PM   #19
Update! Got some more work done
Put up some drywall, installed the kerdi shower niche, laid the abs drain pipe (1/4" slope and leveled it), will back fill with gravel and dirt I removed from the trench and then fill with cement, cut the holes and ran romex for the recessed shower lights, also added a usb plug/outlet behind the toilet...lol
Its comin slowly but surely!
Old 05-24-2014, 08:07 PM   #20
DIY staff
Rewards Points: 7,174
Looking good so far---I hope Bud or Jazz look in and offer some advice on the Schluter System---Mike---
oh'mike is online now   Reply With Quote
tcoche (05-25-2014)
Old 05-25-2014, 01:54 PM   #21
Ok, slight dilema here. Rookie mistake.
Guess I should have looked and measured the bonding flange pipe. The pipe off the flange is exactly 1" long. My drain pipe is 3/4" too high. Didnt realize my drain pipe needed to be lower than the cement slab. It is lower but it needed to be 3/4" lower than it is. So I thought of some options I still have to fix the problem....
A) I can totally dig up the drainage pipes i installed. Remeasure everything and set it 3/4" lower.
B) I can buy some 3/4" styrofoam or whatever schluter calls for to raise the entire subfloor 3/4"....or
C) I can put the bonding flange on my belt sander and trim that 1" pipe down to 1/4" and viola...troubles over!!
What do you think?? I would love to take the easier route and just sand that pipe 3/4".
Thanks!!!
Some pics....
Old 05-25-2014, 05:10 PM   #22
DIY staff
I've never used that drain set---so I can't say 'go ahead' from here---how big of a job is lowering the drain?
tcoche (05-25-2014)
Old 05-25-2014, 11:08 PM   #23
Thanks for tryin to help! I already cut the flange pipe. Worked perfect!! Sits flush and totally level. I took my time cutting it and slapped a sander to it. Came out great!! :D
The Following User Says Thank You to tcoche For This Useful Post:
oh'mike (05-26-2014)
Old 05-25-2014, 11:14 PM   #24
Oh yeah! I did a totally piss poor job cementing that hole and trough in. Guess i will never be a masonry guy. It was my very first attempt at cementing though.
Good thing you wont see it and I do have to put down thin set mortar to attach the shower tray.
Still incredibly angry at myself for totally jackin this cement up!!!
I'll go ahead and embarrass myself with a pic so you all can laugh at me...
Old 05-26-2014, 06:23 AM   #25
DIY staff
I've done worse----
tcoche (05-26-2014)
Old 05-26-2014, 06:30 AM   #26
I've done worse----
Thanks for attempting to make me feel better.
After watching videos online. Im pretty sure I didnt add enough water to the cement mix. Plus, it started to set on me. It got ugly from there.
Now i'm pretty sure I am gonna lay a thin layer of self leveling compound. Just so I am completely level for the kerdi shower tray. Anyone have any recommendations for a leveling compound?? 36" x 36" area
Old 05-26-2014, 08:05 AM   #27
Rewards Points: 808
That combination receptacle / 2x USB port receptacle has to go. You need a GFCI protected receptacle in there.
IslandGuy is offline   Reply With Quote
Old 05-26-2014, 09:46 PM   #28
Rewards Points: 89
Maybe it has a GFCI at the beginning of the run.
REXAMUS is offline   Reply With Quote
The Following User Says Thank You to REXAMUS For This Useful Post:
tcoche (05-26-2014)
Old 05-26-2014, 10:21 PM   #29
Yeah the romex will run directly to this gfci near the light switch. So I'm covered there.
Old 05-27-2014, 07:01 PM   #30
Bought some fun/good stuff...
Bathroom remodel primer dgfit Kitchen & Bath Remodeling 20 10-12-2013 05:41 PM
bathroom remodel in Chesapeake, VA mt dew Building & Construction 2 10-02-2011 08:24 AM
please find flaws in my bathroom remodel plans gregdonovan Kitchen & Bath Remodeling 12 06-16-2009 11:43 AM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 08:28 PM
