Multi-tool To Remove Wall Tile? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 09:17 PM   #1
Multi-tool to remove wall tile?
Never used one before, but am wondering if an oscillating multi-tool would facilitate removing 4" wall tiles from a kitchen backsplash I need to change? If so, what blade should I use? Thanks for any tips.
knute is offline   Reply With Quote
Old 05-03-2011, 09:21 PM   #2
Framing Contractor
Rewards Points: 120
I generally like to use a small drywall knife. Tap it in behind the tile and they will usually pop right off. A lot of the time, the drywall tends to come with it though.
sixeightten is offline   Reply With Quote
Old 05-03-2011, 09:30 PM   #3
Thanks. I've seen a video on doing it that way, and figured to try that also. Was wondering if maybe the m-t might be less damaging to the dry wall. Thanks again for the quick response.
Old 05-04-2011, 12:17 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I suspect the amount of damage to the drywall will depend more on the adhesive that was used to apply the backsplash than the tool used to remove it.
Either they will pop off easily, or they won't.
Old 05-04-2011, 06:11 PM   #5
That makes sense. Thanks.
Old 05-06-2011, 07:44 AM   #6
Rewards Points: 5,336
If the tile was put on properly, it's not coming off without a lot of the drywall.
Ron
Old 05-06-2011, 08:56 AM   #7
Ron
Thanks, Ron. Am finding out it was apparently put on properly. Looks like I'll be replacing dry wall, or installing backerboard, here shortly.
Old 05-06-2011, 11:28 PM   #8
firehawkmph's Avatar
Rewards Points: 1,898
Knute,
use your multi tool to cut the drywall above and below the tile and just take out the whole section and replace it. Much easier. The multi tools work great for drywall.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-07-2011, 09:17 AM   #9
Originally Posted by firehawkmph View Post
Knute,
Mike Hawkins
Thanks, Mike. You're right about that. I already ended up taking out the drywall with the tile. Took about 30 minutes. Installing backer board now. Thanks for the reply.
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
replacing wall tile on uneven surface johnpaul8379 Kitchen & Bath Remodeling 2 02-22-2011 03:26 PM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 06:22 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 11:35 AM
