Mounting Cabinets And Unsquare Walls? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 08:29 PM   #1
Rewards Points: 77
mounting cabinets and unsquare walls?
I am trying to mount some ikea cabinets for my kitchen. The cabinets bolt to a rail that gets mounted to the wall. The cabinets will be set in an "L" shape. I have a problem with the corner. The corner is not square. It is more than 90' (the corner opens up). How can i mount the cabinets and minimize any gaps at the end of the run?
bcbud3 is offline   Reply With Quote
Old 12-07-2010, 11:14 AM   #2
Ultimatetouch
Are these framless cabinets, Euro style? I believe they are. You could probably scrape or cut away some drywall behind the cabinets or straighten the wall out, add a filler to the one side. This is a tough thing to figure out exactly with out being there. I gave you some ideas though. I dont like filler strips or a piece or trim to hide a gap there but sometimes its unavoidable if your completing and gutting the kitchen prior to the cabinet installation.
_____________________
Ultimatetouch
Beautiful kitchen remodeling work by a professional kitchen remodeling contractor.
ultimatetouch is offline   Reply With Quote
Old 12-07-2010, 08:48 PM   #3
Rewards Points: 77
The walls are already finished...i will try to shim out the rail somehow...
Old 12-09-2010, 07:56 AM   #4
Ultimatetouch
Sounds like that makes sense. YOU really have to be there to see which way the walls going and then use a simple solution to make it look its best.
_________________
Ultimatetouch
Kitchen renovations by a reputable kitchen remodeling contractor.
