Mortar Shower Pan Over Concrete - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 06:35 PM   #1
Mortar shower pan over concrete
What do I use between the concrete slab and the first layer of mortar for my pan? Can I use 4 mil plastic?I don't want to bond it because of the small cracks in the slab already.
Bad4you77 is offline   Reply With Quote
Old 03-08-2012, 09:09 PM   #2
Rewards Points: 960
I think it is best to wet the concrete and apply some thinset with a notched trowel, then put in the mortar.
I don't think it's going to matter too much how your mortar sticks to the concrete. Gravity will hold it in place. But it is always a good idea to moisten things when dealing with masonry as well as other endeavors.
cleveman is offline   Reply With Quote
Old 03-08-2012, 09:53 PM   #3
What if I wanted it not to bond to the concrete? The slab has a few cracks and a section I had to fill with concrete and it left cold joints. And I read that the cracks could transfer in to the tile if the mortar bed was bonded?
Old 03-08-2012, 09:54 PM   #4
Thanks for you input and time!
Old 03-09-2012, 07:11 AM   #5
Rewards Points: 960
If you don't want to bond, then almost anything. Plastic, roofing paper.
Relocate shower drain in concrete devouru Plumbing 16 10-03-2015 02:56 PM
Help with shower drain install in concrete floor!! psychomti Plumbing 0 05-17-2010 01:54 PM
Concrete wall shower mikalino Building & Construction 1 04-22-2010 05:59 AM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 02:55 PM
Concrete shower? secutanudu Building & Construction 4 01-14-2010 06:33 AM
