Mortar For Bathtub - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 09:12 PM   #1
mortar for bathtub
Our new whirlpool tub needs a mortar bed. Do we lay the mortar directly on the subfloor? We had planned to replace the current underlayment with ditra - can that go under the mortar, or is that just a waste of money?
Thank you for any assistance!
-Cheryl & Bill
zimmech is offline   Reply With Quote
Old 08-25-2011, 09:42 PM   #2
DIY staff
Rewards Points: 7,174
Use masons mortar ---Right onto the subfloor---no benefit putting Ditra under the tub
Old 08-25-2011, 09:43 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No reason to spend the DITRA under the tub.
The mortar bed (usually sandmix) is placed directly on the floor but you should first put down a piece of plastic or roofing felt or something to separate the mix from the subfloor.
XXX
Old 08-25-2011, 09:45 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh' (speedy fingers) Mike.
Beat me to it.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (08-25-2011)
Old 08-25-2011, 10:23 PM   #5
Thank you so much, Bud and Mike!
Old 08-26-2011, 07:00 AM   #6
We are removing the walls, and just because its easier, are thinking of installing 1/4 drywall right over the existing ceiling. This would avoid having to move the insulation while we work. The house is a ranch. What are your thoughts on this? Could this action result in moisture buildup between the layers and problems down the road? The ceilings are plenty high - 8 feet.
We appreciate your help!
-Cheryl & Bill
Old 08-26-2011, 07:08 AM   #7
DIY staff
Overlaying drywall is done all the time without issue.
You should be fine.----Mike----
Bud Cline (08-26-2011)
"Sandy" mortar on tuck-point repair drm31078 Concrete, Stone & Masonry 7 11-25-2012 09:18 PM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 12:13 PM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 05:53 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
Bond strength of mortar??? figs Building & Construction 7 06-06-2009 04:23 PM
