More On Concrete Countertops. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 03:58 PM   #1
More on concrete countertops.
I am in need of help from anyone familiar with fabricating their own concrete countertops.
I poured my first one last weekend using melamine for the mold. When I took it out last night, I noticed that the melamine had cracked in a few places, the mdf had swelled, and now I have low spots on the top and sides surface. Also, the melamine swelled at the top edge of the mold, from getting wet while screeding I assume.
Have any of you ever seen this? Did I crack the melamine when tapping with the rubber mallet on the bottom? Should I use a better mold material? Is there a trick to it? Etc???
It is a small vanity top, 22"x31". I think there is enough material to grind it flat, not hit the wire in it, and still cover the vanity.
I want to do the 22" x 61" for the master bath.
Another question is how fast can material be removed with the 50 grit pad???
Any help would be appreciated.
cjsdad is offline   Reply With Quote
Old 01-06-2010, 04:47 PM   #2
I envy you. I really wanted to fabricate concrete counter tops for the kitchen, but my wife was afraid to let me try.
Do you have the Taunton book? It's great.
pyper is offline   Reply With Quote
Old 01-06-2010, 05:11 PM   #3
Thanks,
It's been fun, so far, building this whole house.
I only have the Cheng book and video.
Old 01-06-2010, 05:53 PM   #4
Newbie Bill
Rewards Points: 520
Where's Knucklez, he did his kitchen counter and seems to have plenty of experience.
Here is his thread.
my kitchen reno - complete remodel (with concrete countertop)
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 01-06-2010, 06:25 PM   #5
I've read his thread a couple times now. He doesn't have anything in there about having problems with the melamine cracking. That's all I really need to know. I'm gonna try to make this first one work, just don't know how hard/easy it will be to remove about 1/8" of material from the top and sides.
Old 01-06-2010, 08:05 PM   #6
Newbie Bill
Rewards Points: 520
try PMing him, I'm sure he'd have some input.
Bill
Old 01-07-2010, 02:28 PM   #7
Knucklez's Avatar
Rewards Points: 930
never fear, i am here
removing 1/8th inch with a variable speed wet grinder is an impossible task. this is cement, not wood. i do not know how to solve your problem.
how thick was your melemine? i was using 5/8" thick stuff. its quite heavy. i never tapped the bottom of the form. but i tapped and vibrated the sides a lot. never had any problems.
post some pictures.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 01-07-2010, 03:15 PM   #8
I used, I think, 3/4" malamine from HD. It's MDF underneath, and when it cracked, it swelled a lot.
How far do those tops I see with what looks like half the aggregate exposed get ground?
I still am going to do another for the other bathroom.
Looking at it last night, the bottom may be better than the top now.
I was thinking about taping off the top edge of the form next time.
I can always pour this one again if I have to.
Thanks for your input.
Eric
btw,
love your kitchen counters!!!!
Old 01-07-2010, 03:51 PM   #9
Registered User
Rewards Points: 5,186
Glean the tips from these........ http://books.google.com/books?as_brr...G=Search+Books
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 01-25-2010, 09:12 PM   #10
OK, here are some pics. The charcoal is the newest one, brown the first try on the small top. The dark areas on it are the low spots.
I went a different route on the mold this time.
3/4" plywood with 1/16" lexan walls, everywhere.
OMG, how smooth when it came out too. This is right out of the mold, before any grinding or polishing.
I bought the Cheng kit and some wax too, so I'll post more when it's done.
Thanks everybody
More on concrete countertops.-cct9.jpg   More on concrete countertops.-cct2.jpg   More on concrete countertops.-cct8.jpg   More on concrete countertops.-dsci0001.jpg
Old 01-25-2010, 10:06 PM   #11
jlhaslip's Avatar
Rewards Points: 914
I don't 'tap' the form. Use a random orbital sander on the outside of the form vibrates the form enough to settle everything into place.
Nice finish on that black one. one-sixteenth lexan, eh?
jlhaslip is online now   Reply With Quote
Old 01-26-2010, 10:58 AM   #12
Newbie Bill
Rewards Points: 520
Looks great.
Lookin forward to seeing some more photos as you progress.
Cheers.
Bill
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
