-   Kitchen & Bath Remodeling (http://www.diychatroom.com/f80/)
-   -   Moisture-proofing kerdi shower walls (http://www.diychatroom.com/f80/moisture-proofing-kerdi-shower-walls-104587/)
tdarlingt 05-15-2011 04:38 PM
I'm renovating a 3-wall shower using the Schluter Shower ST kit. I'm finished re-doing the plumbing, sub-floor and so on, and I'm ready to start with the thin-set and kerdi.
The question I have is about moisture-proofing the shower wall where the sliding door hardware is attached. The Schluter instructions stress that every hole in the kerdi has to be sealed, and they provide special kerdi products to seal the shower head and control. What about the screws that secure the door to the wall? Ordinarily, I'd just use some silicone.
It just doesn't seem to make sense to carefully seal the whole shower, and then just drill holes in it.
I appreciate any help I can get!.......................Ted
Bud Cline 05-15-2011 06:06 PM
Usually the only screw holes you have relating to a shower door installation are going to be under the door rails. The rails are then caulked as usual. I don't understand the problem.:)
tdarlingt 05-15-2011 06:11 PM
moisture-proofing...
Yeah, maybe you're right. I guess with silicone under the rails and around the screws, there's not much chance of a problem.
Thanks!
