Master Bath Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 05:40 PM   #1
ScottFla40's Avatar
Hey guys, just demo'ed my old mstr. bath due to a leaky shower pan, cut out oldrotted framing, sistered some new studs. I have layout & frame in for the new shower however, I am putting a new wall up on the back side of the shower between the toilet and the shower. I am a little confused. The furring strips in theceiling for the drywall are1 x3's.&for mynewwall framing Iam using 2x4's. Will the new drywall just butt against the outside of the new wall?.. Here are a few pics..
Master Bath Remodel-image-410738903.jpg   Master Bath Remodel-image-3331358256.jpg   Master Bath Remodel-image-2797766882.jpg
ScottFla40 is offline   Reply With Quote
Old 06-23-2013, 06:17 PM   #2
Rewards Points: 13,444
#1 It looks like you used unpressure lumber for a bottom plate, A really big no no when in direct contact with concrete.
#2 It looks like for some reason your ceiling joist are 24" not 16" in center.
Going to have to use 3/4 drywall on that ceiling.
Ceiling always need to go up first, walls are started at the top not the bottom, and there needs to be about a 1/2" gap at the bottom.
Looks like you missing a piece of 1 X 3.
Why would you add 2 X 4's? There not needed and will throw off all the nailers for the wall sheetrock.
Old 06-23-2013, 06:34 PM   #3
ScottFla40's Avatar
I didnt use pt because I read alot & it stated that once pt dries it will shrink & crack the mortar then the tile... Also, the 2x4's are anywhere from 15 3/4" to 16-1/2" apart. House was built in 69. So what your saying is to install drywall ceiling first then frame new wall??
I added the 2x4's on the just that side for support for the new wall going up...
Old 06-23-2013, 06:49 PM   #4
Not sure where you got the info about using pressure treated as a bottom plate but that's building 101 to never have wood in direct contact with concrete.
All the wall framing needs to go up before the ceilings go up.
Old 06-23-2013, 07:03 PM   #5
ScottFla40's Avatar
I will have to find the stuff I read. Maybe I got it confused by reading so much. I'll change the framing for the mortar bed to pt. I have to just figure out the wall issue, today had a mental meltdown, & was about scrap the whole project..
Old 06-26-2013, 01:21 PM   #6
ScottFla40's Avatar
Ok. Tore out what I had. Started fresh. Top plate in first. Plumb bob to pressure treated bottom plate. Started measuring & cutting studs. Pics to follow...
Old 06-27-2013, 12:14 PM   #7
Rewards Points: 304
I'm guessing what you were thinking of was a PT curb? I reframed our basement bathroom shower and originally framed the shower curb out of PT wood along with the bottom plates. While it's the right type of wood to use, the better alternative is to use bricks and mortar to create the shower curb (advised by folks on here), so I ripped up the curb and did it in brick & mortar. Now it's solid as a rock.
NewHomeDIYGuy is offline   Reply With Quote
Old 06-27-2013, 12:40 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
Scott....what was your old shower pan made of and how old was it?
ddawg16 is online now   Reply With Quote
Old 06-27-2013, 12:55 PM   #9
ScottFla40's Avatar
The curb was pt 2x4's, pre-pitch mortar, pvc liner, & mortar bed. It was really poor craftsmanship... Hence, the leak, rot, demo & remodel... Not sure how old it was but the house was built in 69.
Old 06-30-2013, 07:52 PM   #10
ScottFla40's Avatar
Well. Busy this weekend finishing framing the dividing wall between the throne & shower, & the shower niche. I went with pt 2x4's for the curb, then regular kd for the framing. 2x6 blocking on bottom for the pvc liner. Roughed in new exhaust fan. Tomorrow going to install a 3 switch gangbox for light, fan, & outlet. Snapped a few pics... For my first remodel, I am happy withmy progress & results so far..
Master Bath Remodel-image-3826503645.jpg   Master Bath Remodel-image-401204260.jpg   Master Bath Remodel-image-2324591925.jpg   Master Bath Remodel-image-341334165.jpg
Master bedroom and bath remodel toocheaptohire Kitchen & Bath Remodeling 1 03-06-2011 08:22 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 05:31 PM
Tiny Master Bath Remodel??? Orchdirector1 Kitchen & Bath Remodeling 14 10-30-2010 07:24 PM
Master Bath Shower Remodel with images MattCoops Remodeling 4 01-10-2007 03:16 PM
