Masonry Drills Not Enough For Drilling Wall Tiles? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 02:41 PM   #1
Rewards Points: 682
Masonry drills not enough for drilling wall tiles?
I've heard that masonry drills, which I used for drilling holes in stucco and concrete, are not good for drilling holes in shower tiles, that they will crack them. I've been told I should use diamond tipped drills instead (with the circular head instead of pointy head). Is this true?
darsunt is offline   Reply With Quote
Old 03-02-2012, 04:52 PM   #2
Rewards Points: 512
yes, you do not want a drill to be on hammer when drilling shower tiles. you want to have a regular drill on the slowest setting. put lots of water on it and let the bit do the cutting, dont let the drill bit heat up to much and burn, just keep it wet and let it cut.
princelake is offline   Reply With Quote
Old 03-02-2012, 06:30 PM   #3
MarginallyQualified
Rewards Points: 2,464
Best luck I've had was with "glass" bits.
http://www.xenostone.com/xenostone_s...it/prod_6.html
Old 03-02-2012, 08:10 PM   #4
i use a hammer drill on these all the time
only cracked a tile once
i tried glass and tile bits, and it took me 20 minutes to drill the hole, next hole i used a hammerdrill (hilti te6) and it took all of 6 seconds. my applications are commercial though, and generally thicker/tougher tile than what is probablly in a residence.
sevenlol is offline   Reply With Quote
Old 03-03-2012, 01:16 AM   #5
Rewards Points: 682
Sounds like cutting shower tile is much more difficult than I thought.
Old 03-03-2012, 01:17 AM   #6
Rewards Points: 682
But it sounds like you don't really need a diamond bit drill ($19) if you are patient.
Old 03-03-2012, 04:51 AM   #7
DIY staff
Rewards Points: 7,174
I buy my diamond bit from Hong Kong for less that $2.00 each (EBAY)
Only good for two holes--
I ,too, have used a masonry bit and hammer drill on porcelain tiles-No failures yet-
A diamond bit is the proper tool---
Old 03-03-2012, 09:18 AM   #8
Rewards Points: 190
If they are ceramic tiles, soft clay with a glaze, it's easy to drill and cut. If they are porcelain tiles, it's harder to cut and especially harder to drill and diamond bits are needed.
zircon is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 08:45 AM
swap out bath wall tiles: re-tile or remove backerboard NJoytheRide Building & Construction 8 04-16-2011 07:52 AM
New opening in masonry wall Jeepsail Building & Construction 2 01-17-2010 02:50 PM
