Marble Countertop Excess Length Doesn't Leave Enough Space For Stove! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 01:59 PM   #1
Marble countertop excess length doesn't leave enough space for stove!
I moved into a home with no appliances. Before ordering an electric range, I measured the space and came up with 30". Since the standard ranges are all slightly less than 30" I assumed one would fit . Today it was delivered and uncrated, and I have just discovered that the space NARROWS toward the back, making it impossible to put the range in place. The marble countertop, rather sloppily installed, overlaps the cabinet by almost half an inch, on one side only of the range space. MY QUESTION: Can the excess edge of the marble countertop be trimmed away with the countertop in place? Or am I about to embark on an expensive project to replace that piece of countertop with one that's slightly narrower?
As Charlie Brown would say, "Argh."
BTW, I checked range widths online and the one I ordered is narrower than most by a fraction of an inch, so exchanging it for a narrower model is not a solution.
sbrink is offline   Reply With Quote
Old 12-28-2010, 05:21 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,288
I'll bet with an angle grinder, you can nip away at the counter top. I don't know how it will end looking though.
Good luck and hopefully someone with experience can offer more useful assistance.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
sbrink (01-04-2011)
Marble Tile Countertop? Sportbilly Remodeling 16 12-09-2012 04:29 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Should I leave space between toilet flange and subfloor? pttcc Plumbing 8 09-08-2010 09:36 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 08:05 PM
Sanding Cultured Marble Countertop? a2116 Remodeling 2 05-31-2007 05:39 AM
