Making A Tile Ledge - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 09:29 PM   #1
Hi, this is my first post here.
I'm starting to plan out a renovation to my tub surround. There is some damage, so I want to gut it out and do it right.
I will be removing the sliding door and also that acrylic trim from the corner and the tub ledge. I'm going to retile the surround, and I was wondering how to make a ledge across the front.
If I remove that corner trim on the drywall is it possible to tile flush from that corner across the front of the tub to the opposite wall (not pictured, tub meets it perpendicular) to create a ledge? how would I go about building the framing for the tile surface? Would I use cement backer board like we do for surrounds?
Thanks for the feedback.
This will be my first bathroom project. I did a tile floor once and I really enjoyed it. I'm looking forward to this.
Harlan07
harlan07 is offline   Reply With Quote
Old 10-29-2012, 09:37 PM   #2
Rewards Points: 236
DO NOT use wood, of any kind. i used paver bricks when i did my curb. then it was covered with kerdi
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
harlan07 (10-29-2012)
Old 10-29-2012, 09:45 PM   #3
Fixn it, thanks for responding.
How do you bond the pavers to the tub? How should I go about getting everything flush with the drywall corner?
Old 10-30-2012, 06:53 AM   #4
DIY staff
Rewards Points: 7,174
What exactly are you replacing?
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 5 10-15-2012 02:31 PM
Tile shower leaking gregsenne Plumbing 9 10-02-2012 09:00 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 07:58 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
