Low Ceiling Shower Construction - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 08:04 PM   #1
I am building a bathroom in the basement/Man Cave of my house. The Ceiling is approximately 76 inches. I do have a ceiling fan located near the shower. Above the ceiling is TGI's/manufactured joists 16 Inches on center (no insulation). I installed vapor barrier 6 mill visqueen on the entire ceiling & had about half of the mold tough green board up before I read that green board should not be used directly above showers, that you should not place vapor barrier behind green board, and that if green board is placed on a ceiling the maximum spacing allowed is 12 inches. I am planing on tiling all the walls in the bathroom with 3/8" marble up to the ceiling. Should I take down the green board, remove the vapor barrier in the non shower areas, leave the vapor barrier in the above shower area, place 5/8 sheetrock in the non-shower areas (without the visqueen vapor barrier), and place hardibacker and tile (with the visqueen vapor barrier behing the hardibacker) in the area above the shower?
Thank You for any help you may be able to provide.
ashelley is offline   Reply With Quote
Old 02-23-2012, 08:59 PM   #2
MarginallyQualified
Rewards Points: 2,464
Header/block out the area immediately above the showering spot.
Gain those inches while you can.
Old 02-23-2012, 09:30 PM   #3
I am not sure what you mean by header out. I did plan on sheetrocking between two of the TGI's to allow room for the shower head (which will be an overhead type).
Old 02-23-2012, 11:54 PM   #4
Is my proposed plan the best way to go. I do not want to get into structural changes.
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
how to reduce splash for roman shower (wall vs ceiling shower head) MLMIB Kitchen & Bath Remodeling 2 12-26-2011 03:12 PM
shower ceiling issues.. kevin97 General DIY Discussions 26 12-10-2011 12:36 PM
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 02:41 PM
Is it ok to use the shower without a ceiling in the bathroom? Bigguy0 Building & Construction 5 10-24-2009 08:26 PM
