Loose Shower Panels - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 09:28 AM   #1
Loose Shower Panels
I have 2 loose shower panels that are seperating from the wall. One is loose from the top to the bottom. Whats the best fix?
Jrev is offline   Reply With Quote
Old 01-07-2013, 09:37 AM   #2
Rewards Points: 13,712
What are they made of?
Got a picture?
If there just plastic I use this under the panel, roll over the panel with a rolling pin to smoosh it out then tape the seam with blue tape untill it cures.
http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
Old 01-07-2013, 09:48 AM   #3
I am new to this chatroom. You referred to "this"? Assuming there is a picture attached? I don't see it. Second, no picture, not positive on the material. I am assuming fiberglass, panels are about 1/4" - 3/8" thick, has the fake marble look. It is a older house that was built in later 70's, early 80's. Thanks and sorry for the newbie type questions.
Old 01-07-2013, 09:58 AM   #4
Opps, forgoot to add it, my bad.
Old 01-07-2013, 10:17 AM   #5
So I would need to remover the existing panels to apply the adhesive to the panels? I was hoping to not have to do that but since the panels seem to be loose towards the bottom I'm not sure that is possible or an adequate fix.
Old 01-07-2013, 10:22 AM   #6
And without being there to see it hard to suggest how to fix it.
I do know if it's not fixed soon you'll be removing them anyway to fix the mold and rot behind them.
Onyx Shower Wall Panels and Hardie 500 1/2" substrate MOsteve Kitchen & Bath Remodeling 22 07-25-2011 07:25 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Shower Door Transom is loose 2031pratt Plumbing 0 12-28-2010 11:26 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Loose sand under shower tiles pictures RodJ Kitchen & Bath Remodeling 1 03-30-2009 06:26 PM
